Need SMT component value
Benoit Pothier
Hi ,
26 VAC has been put on a DOME Cameras instead of 12DC.
4 SMT parts blewed up . I have a working one that I can read the marking but
I cannot find what are the value of them.
Here are the 4 parts (i.e:marking on the parts) :
EJ6 d.....Seems to be a SMT capacitor
DA7 J.....Seems to be a SMT capacitor
6R8.....I'm assuming a 6.8 Ohms resistor
2L.....Very small SMT diodes (2 pins)
These parts are connected to the 12V input.
Can anybody help with the value of these components ?
Tks...
Hi ,
Tks...
try the IC Master on the web it will give you equalivent parts from
other manufacturers, pin outs etc. function etc.
F
Franc Zabkar
Hi ,
Not 100% sure about the caps, but you can verify them for yourself
here (pages 11 & 12):
http://web.archive.org/web/20030524192212/http://www.iaea.org/programmes/naal/pci/pages/smdman.pdf
http://www.fpga4fun.com/external/SMD/smdman.pdf
25V 2.2uF
20V 10uF
FWIW, this 3-pin double diode also uses the 2L marking code:
http://www.nxp.com/acrobat_download/datasheets/BAT754_SERIES_2.pdf
2L BAT754A Phi J SOT23 Schottky barrier double diodes
Tks...
- Franc Zabkar
Bentech
Tks a lot.
For the L2 diode , it's not a SOT23 pkg.
It's a 2 pins diode.
I tried to find a relataion on the net but without success.
F
Franc Zabkar
L2 or 2L ?
It would help if you traced the circuit. Sometimes designers place a
reverse biased rectifier diode, eg 1n4001, across the input terminals
for reverse polarity protection. An AC input voltage would have short
circuited it.
- Franc Zabkar
Bentech
It's marked 2L on it.
It's in serie with the 12 volts line.
F
Franc Zabkar
In that case it is probably a 1A rectifier which provides
non-destructive reverse polarity protection. You should be able to use
a 1N4001 if you can make it fit. The diode's current rating will be
reflected in the rating of the supply.
Have you verified whether the camera uses a regulator further
downstream? If it doesn't, then you can expect more damage elsewhere.
- Franc Zabkar
