Need some creativity
bonedoc
Dec 21, 2011
122
So, I have a situation where I need some creativity. I have a plastic shaft that is 1" long and has a diameter of 1/2". So, It is small.
I need to rotate it 1 time, 360 degrees at the push of a button. I need to turn a full revolution in about a second. This button will be on a chip. I have a few ideas, but they all have pros and cons, so I wanted to see if anyone here has some creative ideas, or know of some nice, very small switches.
-servo- Pro- specific. Con- bulky, expensive...and dont have enough hardware or ccp modules left for them
-small stepper motor. Pro- specific. Con- fairly expensive still, and 4-6 wires. Do I need a fancy stepper when I only need 1-2 steps? Probably not.
-Small DC motor. I have a very small motor and gears. It is 1" long and 1/2" diameter. It runs on 6v, has high torque, and will do 1 RPM. Con- I dont know of a small switch with a lever and mounting holes. This would be nice....
Any other ideas? Time alone is not accurate enough.
jackorocko
Apr 4, 2010
1,284
What do you consider expensive? Small steppers on ebay come for less then $20 dollars, out of an old scanner even less. You still haven't said how much torque you need. Probably the most expensive cost of a stepper will be the control circuitry.
