Need Some Help Finding the Right MOSFET
Supercap2F
Mar 22, 2014
550
Hello Everyone!! :)
Well I'm working on a project that uses a single Li-poly battery for it's power. But unfortunately, I could only find a Li-poly cell that has no protection circuity on board that would fit my needs (Here).
So, I need to design an under voltage protection circuit. I don't need any over voltage protection, as I'm just going to charge them up with something like this. First, I thought that I could just find a chip to do the protection, but I couldn't find any that would just do under voltage protection. I also need the protection circuit to drop hardly any voltage at all, because of 3.3 volts power supply requirements of the rest of my circuit.
After doing a whole lot of thinking, I decided to try something like this:
So the way I would think this would work would be: power comes into the LDO regulator from the Li-poly battery at Vcc. Then the MOSFET pulls the Enable pin high, which then turns on the regulator. But then when the battery drops to about 3.45V the MOSFET stops conducting and R14 pulls the Enable pin low, turning off the regulator and the rest of the circuit (at 3.45 volts the regulator is almost to the point where it won't work anymore due to it's 0.13V drop out voltage).
Now the problem is, I have no idea how to select the MOSFET, or even if it's around the right way! :confused::p I wonder if someone could point me in the right direction as to selecting it? Or even if this design is plausible!
Thanks very much Everyone!!! :)
Dan
Arouse1973
Adam
Dec 18, 2013
5,178
Hi Dan
Why could you only find a battery without protection? Batteries with protection have been qualified to be safe under most conditions. Please reconsider. What battery spec do you need.
Cheers
Adam
Supercap2F
Mar 22, 2014
550
Hey Adam!
Well I looked just about everywhere that I trusted. The whole project actually uses two batteries, one for some motors and one for the controller circuit. The motors will draw about 3A max, and they don't go through this part of the circuit. The controller circuity that will be going through the regulator will draw about 2A max. I would like to have at least 1000mAh capacity too.
Those 1000mAh batteries I found have a 20C rating, which means they can have about 20A drawn out. They're just the perfect size too...
Thanks Adam! :)
Dan
Supercap2F
Mar 22, 2014
550
For the controller circuit: 3.3V
For the input of the regulator: 9V or less
Dan
Supercap2F
Mar 22, 2014
550
Well I would like to have separate batteries since the motors will cause a whole lot of noise on the power lines.
Dan
Arouse1973
Adam
Dec 18, 2013
5,178
So for Lipos you got a few choices as you you know. 4.2, 8.4, 11.6 volts. You need to choose one.
Adam
Supercap2F
Mar 22, 2014
550
Well the problem with the 8.4V ones now that I think about it, would be increased weight. So the 4.2V ones would be the best for this project.
Thanks again for your time Adam!
Dan
Supercap2F
Mar 22, 2014
550
Yeah pretty much. :) Less then 8x5cm in size would be about right too.
Supercap2F
Mar 22, 2014
550
Well that one only has a max discharge of 2 Amps, I need at least 3A for the motors...
Edit: I take it back! I actually need one the can discharge at at least 3.2A, turns out the motors have a 1.6A stall current. :oops: Sorry about that!
Dan
Arouse1973
Adam
Dec 18, 2013
5,178
Ok so you might need a different battery. Have you looked at model RC batteries?
Adam
Supercap2F
Mar 22, 2014
550
Yes it will have inside the pack. Any batteries that have a set of wires and or connector when sold must be qualified. It's the law over here.
Adam
Hmm. Okay, that one looks like it might work then. But I don't like how its coming from Hong Kong (sending payments over their kind of creeps me out :D)... I'll see if I can find one like that from somewhere local.
Thanks again Adam!!! :)
Dan
Arouse1973
Adam
Dec 18, 2013
5,178
Yeah no probs it was an example to show you what's out their. Check with your local hobby shop.
Adam
