Need some help searching identification
  • Thread starter Pierre-François (f5bqp_pfm)
  • Start date
Hi the Group,
On the following module (see the picts into the links below) I'm
searching to identify the following components:
IC1: L02
BV67W
Probably a PIC (?), nevertheless for sure a programmable component.
D4: 6F
42
D3: R12
D2: 6.2B
or
8.2B
93
Difficult to read clearly even under the binocular.
Here are the picts:
Pile: http://cjoint.com/?AKwxdrhymgr
Face: http://cjoint.com/?AKwxfvUq7kI
The most important is IC1.
D3 has six pins, very strange for a rectifier, my smd code book doesn't
have an "R12".
Many thanks for your help.
Pierre-Francois, f5bqp
Piotr Piatek
IC1: L02
BV67W
Serial EEPROM with I2C bus, some variant of 24C02, perhaps BR24L02
npn transistor BC818-25
Le 23/11/2011 07:57, "Pierre-François (f5bqp_pfm)" a écrit :
Hi the Group,
IC1: L02
BV67W
D4: 6F
42
D3: R12
D2: 6.2B
or
8.2B
93
Here are the picts:
have an "R12".
Hi the Gang,
Many thanks for these first replies, I'll continue to investigate, your
guesses are interesting and bring me on the good direction.
If any other ideas don't hesitate, you're welcome.
All the bests and thanks again.
pf, f5bqp
Le 23/11/2011 15:17, Morten Leikvoll a écrit :
Here are my guesses.
D2: 6.2 zener or tranzorber (protection) diode.
C2 looks like a high voltage cap. Is this module connected to some
transmission (tele) medium?
It would help with a description what this module does and/or where it came
from.
If IC1 is a serial eeprom, there must be some logic int (or ext) to
read/write it. If int, maybe d3 is some tiny cpu, if ext it may be some dual
port logic. Or maybe a hall sensor? It looks like the i2c bus (from the L02
chip) is also connected to this chip, so my guess is a sensor or maybe even
a unique serial number chip (check dallas, now ti)
The wires seems to be gnd,power,scl and sda.
You could also try http://www.smdok.com/ or
http://www.marsport.org.uk/smd/mainframe.htm (google for smdcode)
If you also could remove the white label, we could try to reverse engineer
the netlist and get more out of it. I see there is a lot of 51R resistors
there..
Hi Morten & the Gang,
I forgot to answer your question, so here it's:
This small module is a dongle associates to a DVDROM which contain the
update of the cartography for a car GPS.
When you open the motorized screen which flip from 90°, you have on the
side of the GPS screen a 3.5mm jack socket to plug this dongle.
then you insert your DVDROM to update the hard-disk of the GPS unit.
The 3.5mm jack is a 4 pins jack going to the 4 color wires you can see.
The 3.5mm jack isn't on the picture.
Hope you understand better the functionality of this small module.
This is a key, you update once then you cannot update another GPS system...
The problem is that I'm going to add from time to time some remarkable
points to the cartography, then I'll update much more than once!
So I need to find a way to update that dongle.
Tomorrow I'll remove that white label to do another pict for you.
All the bests
pf
Hi Piotr,
I've checked the BC818-25 datasheet, they're saying 6Fs for the marking,
so I don't know.
Concerning the 24C02 & the BR24L02 these are serious possible
candidates, however the both datasheet don't mention any marking code so
I don't know either.
But it's very probable it's an I2C EEPROM thinking to the function this
small dongle is doing.
All the bests.
pf, f5bqp
Piotr Piatek
so I don't know.
The marking 6F looked familiar to me, because we use these transistors
at work, but I think that I was wrong. It's more likely some dual
diode, as Franc Zabkar suggested.
from.
there..
Here is as promised yesterday night the pict with the white sticker
removed, we can see that D2 is in // with C2, so D2 could be a transient
suppressor on to the power lines "just in case"?... Or a Zener at 6.2v
as you mentioned earlier.
http://cjoint.com/?AKyoKzTaOsx
Another pict showing the 3.5 jack:
http://cjoint.com/?AKyoS7CQtgN
pf
Hi Piotr,
No problem, the investigation is continuing... :)
pf
Le 24/11/2011 11:40, Morten Leikvoll a écrit :
Here is a 6pin serialnumber IC.. Could be something similar.
http://www.maxim-ic.com/datasheet/index.mvp/id/2903/t/al
Hi Morten,
Wouhaa! First time I see such a silicon registering tool!
Today you make me less crazy than this morning! Thanks for that... ;-)
Based on your description of the board, it may be a fit.
Yes and no, because each time you get a new DVDROM you get a new dongle,
so the serialnumber IC isn't attached to the GPS.
May be to the DVDROM itself, could be, but the DVD production should be
a mess in that case...
pf
Hi Again Morten,
I measured precisely the D3 packaging with a caliper, and it's smaller.
1.3mm large , 2.0mm Long
The PIC10F is SOT23 packaging which is 1.3mm large BUT 2.7mm Long.
On the same side of this tiny board where D3 we're trying to identify is
you have D4 which is an SOT23 packaging, you can see it's bigger.
pf
Le 24/11/2011 15:17, Morten Leikvoll a écrit :
F
Franc Zabkar
Hi Again Morten,
pf
ISTM that the whole thing may be as simple as a solitary I2C EEPROM.
I'm guessing D3 is a diode array that protects the clock and data
inputs from ESD.
Vcc ---|<|---o---|<|--- Gnd
SCL / SDA
I think you're correct in that D2 appears to be a transient voltage
suppressor (or maybe a zener). Its breakdown voltage is probably 6.2V
whereas the supply voltage for the EEPROM would be 5V or 3.3V.
- Franc Zabkar
F
Franc Zabkar
Try pulling up the EEPROM's Write Protect pin to Vcc. That should
disable any writes.
BTW, there is a 51 ohm resistor in series with the Vcc input. This
would suggest that the current draw of the entire PCB needs to be very
low. For example, a current draw of 10mA would result in an
unacceptably high voltage drop of 0.5V. According to the data sheet of
the BR24L02, the voltage drop across the 51 ohm resistor during write
mode would be about 60mV. That sounds OK.
256×8 bit electrically erasable PROM
BR24L02-W / BR24L02F-W / BR24L02FJ-W
BR24L02FV-W / BR24L02FVM-W:
http://www.rohm.com/products/databook/eeprom/pdf/br24l-e.pdf
- Single power supply (1.8V to 5.5V)
- Write (5V) : 1.2mA (Typ.)
- Read (5V) : 0.2mA (Typ.)
- Franc Zabkar
Le 25/11/2011 09:29, Franc Zabkar a écrit :
It's not the same part, but it has an R12 marking:
SR12, RailClamp, Semtech, Low Capacitance TVS Diode Array:
http://www.semtech.com/images/datasheet/sr12.pdf
- Franc Zabkar
Hi Franc,
The Semtech could be a good candidate for the function, however it has
only 4 pins, D3 has 6, and D3 is much more tiny, the Semtech is SOT143
2.8mm long .
pf
F
Franc Zabkar
Hi Franc,
2.8mm long .
pf
That's why I wrote that "it's not the same part". Nevertheless I
suspect your part would have a similar function. In any case, what is
preventing you from performing a simple test with a multimeter? AISI
the circuit is essentially just an EEPROM on a stick and should not
require much effort to "reverse engineer".
- Franc Zabkar
F
Franc Zabkar
Here is my best guess as to your circuit layout:
Vcc 51R 51R
___ Vcc1 ___ Vcc2
Red (4) o-|___|--+---+-----|___|---+--------> to EEPROM pin #8
R1 | | R2 |
| | D2 |
--- z ---
C2 --- A 6.2B --- C3
R10 | | R11 |
___ | | ___ |
Blk (2) o-|___|--+---+-----|___|---+--------> to EEPROM pin #4
51R Gnd1 51R Gnd2
Gnd
Vcc1
SDA 51R ^ 51R
___ D3-A| ___
Yel (1) o-|___|--------+--------|___|----+---+------> EEPROM pin #5
R8 | R4 | |
^ D4-A ^ --- C5
Gnd1 -+-
Gnd2
Vcc1
SCL 51R ^ 51R
___ D3-B| ___
Blu (3) o-|___|--------+--------|___|----+---+------> EEPROM pin #6
R7 | R3 | |
^ D4-B ^ --- C4
Gnd1 -+-
Gnd2
Vcc2
| | R5| |R6
1K | | R9 | | | | | 2K2
'-' .-------V-------. | '-' '-'
-----| 1 A0 Vcc 8 |--- | |
.--| 2 A1 WP 7 |--. | |
|--| 3 A2 SCL 6 |--)---'----)------> to D3-B via R3
|--| 4 Gnd SDA 5 |--)--------'------> to D3-A via R4
| BR24L02 |
| R12 | | --- C1
| 10K | | ---
Gnd2
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
I suspect that the pinout of D3 is as follows:
D D
pin2 ---|<|---o---|<|--- pin1 D3-A
pin3
D D
pin5 ---|<|---o---|<|--- pin4 D3-B
pin6
I confess that I don't understand the purpose of D4.
- Franc Zabkar
Vcc 51R 51R
___ Vcc1 ___ Vcc2
R1 | | R2 |
| | D2 |
--- z ---
R10 | | R11 |
___ | | ___ |
51R Gnd1 51R Gnd2
Gnd
Vcc1
SDA 51R ^ 51R
___ D3-A| ___
R8 | R4 | |
^ D4-A ^ --- C5
Gnd1 -+-
Gnd2
Vcc1
SCL 51R ^ 51R
___ D3-B| ___
R7 | R3 | |
^ D4-B ^ --- C4
Gnd1 -+-
Gnd2
Vcc2
| | R5| |R6
| BR24L02 |
| R12 | | --- C1
| 10K | | ---
Gnd2
D D
pin3
D D
pin6
- Franc Zabkar
Hi Franc,
Back to home after two days outside I'll look at that, thanks for your
work, I appreciate very much.
All the bests.
pf
Yes I'm going to do it.
pf
AISI
