Need temporary power supply for laptop
mm
It seems I mailed home the powersupply cord and transformer for my IBM
ThinkPad 600E, instead of putting it in my suitcase.
So I need something to use until the package I mailed comes.
It says 15.5 to 17 volts DC, 56 watts, and I have a whole bunch of
possible adaptors to use, but if I have to make one from a transformer
and diodes, how much ripple filtering would I likely have to do to
simulate the original power supply. None at all? So many microfarads
worth before and so many after the diodes?
I have a 40 year-old EICO kit scope that I've never fully understood
how to use -- I bought it used and assembled -- but this might be the
push I need to finally learn how to use it for something more than the
most basic use. I also have loads of diodes and an assortment of
capacitors of all sizes, plus I can buy more if I need to. But since
this is only for a few weeks, until the box comes in the mail, and I'm
not going to be going anywhere with it, I don't want to go to more
trouble than necessary.
Thanks.
If you are inclined to email me
for some reason, remove NOPSAM :)
Meat Plow
Your basic regulated full wave bridge supply with a 470 uf cap across the
output will work just fine. Make sure it can deliver a steady 2 amps.
Smitty Two
Thanks.
Ya didn't hear it from me, but when I left my laptop power supply in
Hawaii, I bought one at CompUSA to use until my friend could ship the
original one back. (30 day money back guarantee and all)
Of course, you won't learn any electronics that way...
mike
What is a "basic regulated" full wave bridge supply?
The terms "regulated" and transformer/diode/cap seem to be incompatible.
If I understand what you wrote, it's a very risky recommendation for
someone skilled in the art. But someone skilled in the art would
not have asked the question.
If you don't have a REGULATED power supply within the allowable range,
give it up.
If the original posting is an accurate description of the thought process,
the OP should do his laptop a favor and wait for the mail.
mike
I guess we now know why Cusa is going out of business...
it's YOUR fault ;-)
jakdedert
Thanks.
Won't work for you, because you're at home and your supply is in the
mail, but...on the road, when I've lost or forgotten various common
supplies, I've done this: go to the desk clerk and ask to look at
supplies left behind by former guests.
If your laptop, or cell phone is a common brand/model, there's at least
a chance they'll have the exact one. If you have a problem with
appropriating someone else's property, just leave it in the room when
you check out (for the next guy).
jak
mike
Meat said:
It's a basic regulated full wave bridge supply.
Repeating the words does little to clarify.
A "basic full wave bridge supply" is (to me) by definition UNREGULATED.
If it's regulated, the fullness and waveness and bridgeness is
irrelevant to the load. Or the pile of smoking plastic that once
was the laptop in question.
Meat Plow
It is UNREGULATED when you drop the word REGULATED out of my description.
"It's a basic regulated full wave bridge supply"
Had I meant UNREGULATED my description would have been;
"It's a basic full wave bridge supply"
HTH
HAND
mike
HTH
HAND
OK, listen up!
The op suggested using a transformer and some diodes and asked how much
capacitance to use on the output to properly power his laptop.
Your answer could be easily interpreted (by someone unskilled in the
art) to mean
that the suggested supply would work as long as it had 470uf and
delivered a steady 2 amps.
The fact that you stuck the word "regulated" into a discussion of
an unregulated transformer, diode, cap supply may make YOU feel better,
but it won't help the poor guy who thought he took your advice and blew
up his laptop.
YOU GAVE BAD, BAD, BAD ADVICE.
The possibility that YOU might have the experience, test equipment,
parts to make it work doesn't make it good advice for someone less
experienced/equipped in the context of THIER situation. Even if 100
of us could successfully implement it does not matter. The only
thing that matters is whether the OP could be successful.
Most of the questions asked here are from people who have not a clue
about what they're asking. That's why they're asking. It's clear
from the wording of the question. They want a simple solution to
a possibly complex and inadequately specified problem.
They have no way of sorting bad advice
from good advice. Stated another way, if they had the experience
to tell good advice from bad, they probably would not have had
to ask the question.
Most of the solutions presented to those questions are ill conceived
given the context of the question and the obvious lack of experience
expressed by the questioner.
The key to teaching is to put yourself in the shoes of the person
asking the question, understand what's being asked and deliver advice
in a context that can be understood, unambiguously and SAFELY executed by
the questioner with HIS level of experience and tools...not yours.
You also have to make some assumptions about what he didn't ask
and the ramifications of those missing pieces. Those unknowns
need to be addressed by further questions or a tutorial on other
factors and how they affect the answer.
Competency doesn't hurt.
Many of the newbie questions asked here would be properly answered by,
"given the level of experience suggested by the formation of your
question, the risk/reward ratio of this endeavor is unfavorable
....and here's why..."
Problem is the "here's why". To state that would require...there's
that word again...competency.
The handle fits, wear it proudly...
Dave Plowman (News)
That seems a bit low to me. I'd make it 6,800µF for 2 amps. But 56 watts
even at the high end of voltage is over 3 amps - not 2.
Dave Plowman (News)
Be worth getting a learner book on electronics since things like values
needed for smoothing a given power will be explained. And the fact that
the DC voltage produced from an AC one depends on the type of
rectification too.
So if we look at the basics, 56 watts @ 17 volts is 3.3 amps.
Full wave rectification gives approx 1.4 x the AC supply
To smooth 4 amps needs 10,000 µF.
So a 12 volt 4 amp transformer, 4 amp bridge rectifier, and 10,000 µF
should give you 16.9 volts adequately smoothed.
