Jeffrey Lebowski said:
quoting from that source.....
Chemical equation
Generally, the chemical equation for stoichiometric burning of
hydrocarbon in oxygen is as follows:
C_xH_y + (x + \frac{y}{4})O_2 \rightarrow \; xCO_2 +
(\frac{y}{2})H_2O
For example, the burning of propane is:
C_3H_8 + 5O_2 \rightarrow \; 3CO_2 + 4H_2O
The simple word equation for the combustion of a hydrocarbon in oxygen
is:
\textrm{Fuel} + \textrm{Oxygen} \rightarrow \; \textrm{Heat} +
\textrm{Water} + \textrm{Carbon\ dioxide}
If the combustion takes place using air as the oxygen source, the
corresponding equations are:
C_xH_y + (x+ \frac{y}{4})O_2 + 3.76(x+ \frac{y}{4})N_2 \rightarrow
\; xCO_2 + (\frac{y}{2})H_2O + 3.76(x + \frac{y}{4})N_2
C_3H_8 + 5O_2 + 18.8N_2 \rightarrow \; 3CO_2 + 4H_2O + 18.8N_2
The simple word equation for the combustion of a hydrocarbon in air
is:
\textrm{Fuel} + \textrm{Air} \rightarrow \; \textrm{Heat} +
\textrm{Water} + \textrm{Carbon\ dioxide} + \textrm{Nitrogen}
bottom line, I couldnt see where CO by itself is produced.......by
combusting propane and oxygen or propane and air..... co2, yes, co,
no.
