Nested parens are driving me nuts
Jim Thompson
some of my SPICE ventures get to be Rube Goldberg-esque -- and the nested
parenthesis are probably the reason.
how is it possible to break the equations into manageable bite-sizes so that
I can de-"erroratate" my sims?
Get better at Algebra ?:)
Read up on functions (.FUNC) and expression syntax.
...Jim Thompson
Johnson
Q
qrk
Use a text editor that keeps track of paren pairs. Ultra Edit may do
this and Semware's editor does this.
Jim Thompson
UltraEdit does it quite nicely. But if you need an editor to keep
track I don't know that I'd trust your Algebra ;-)
...Jim Thompson
Johnson
Here's a vacuum model (can you tell the author is Italian?) which I am
trying to shoe-horn into EWB (Multisim8) -- of course PWR and PWRS isn't
supported for the VCCS , but (1+SGN(x)) can be employed. I have pulled that
portion apart and it works. It's the VCVS which is causing the program to
terminate. The model purportedly works in SwitcherCAD. Instead of passing
the capacitor and resistor PARAMS I insert the values where appropriate.
I have gotten other vacuum tube models to work in Multisim8.
..subckt 6dj8i 1 2 3 ; placca griglia catodo
+ params: mu=28 ex=1.3 kg1=330 kp=320 kvb=300 rgi=2k
+ ccg=2.3p cgp=2.1p ccp=.7p
e1 7 0 value=
+{v(1,3)/kp*log(1+exp(kp*(1/mu+v(2,3)/sqrt(kvb+v(1,3)*v(1,3)))))}
re1 7 0 1g
g1 1 3 value= {(pwr(v(7),ex)+pwrs(v(7),ex))/kg1}
rcp 1 3 1g
c1 2 3 {ccg}
c2 1 2 {cgp}
c3 1 3 {ccp}
r1 2 5 {rgi}
d3 5 3 dx
..model dx d(is=1n rs=1 cjo=10pf tt=1n)
..ends
Jim Thompson
e1 7 0 value=
re1 7 0 1g
rcp 1 3 1g
c1 2 3 {ccg}
c2 1 2 {cgp}
c3 1 3 {ccp}
r1 2 5 {rgi}
d3 5 3 dx
.ends
Maybe break down the pieces into small functions and then see where
the error reports lead you.
...Jim Thompson
Johnson
Yes, that was I resorted to -- I built up the model with multiple nodes
until it worked, then substituted back -- in some SPICE-ware LOG returns
Natural Logarithm, not in Multisim where LN must be used.
the nested parenthesis are probably the reason.
so that I can de-"erroratate" my sims?
Zeus has a configurable find matching brace feature:
http://www.zeusedit.com/features.html
Note: Zeus is shareware (45 day trial).
The feature is located under the Edit, Find Matching Brace menu.
NOTE: If you this menu reports no braces found you will need to use
the Options, Properties menu and in the Templates section define a
set of matching braces strings.
Jussi Jumppanen
Author: Zeus for Windows IDE
