Mike Monett
- Jan 1, 1970
- 0
John said:My Efratom uses a 20 MHz VCXO. A divider chain creates 5 MHz and
312.5 KHz. They're mixed in an xor gate to make 5.3125 MHz. The 20
MHz is also multiplied to 60 MHz. The 60 is combined linearly with
the 5.3125 and drives an SRD in a resonant cavity. Somehow some
line in this mess hits the 6.834687 GHz rubidium resonance, 114th
harmonic or something. The power must be minute.
I don't quite get this, but that's what the manual says. The
circuitry is fairly simple, just HC logic and a few transistors.
The whole thing is about as big as a coffee mug.
John
Thanks, John. That's for rubidium - cesium is a bit higher at
9,192,631,770 Hz. This means an even higher multiplier and more
phase noise or jitter, if you prefer. The snr degredation at a
multiple of 114 is already 41 dB, but that's not counting the 1/F
noise. It would seem they need the performance of a YIG to hit the
cesium line and stay on it. So the basic oscillator must be very
good!
Now how do they package a low 1/F VCXO, synthesizer logic, and the
needed multipliers and mixers into such a small low-power package?
The problem is even worse with the NIST-F1 cesium fountain. There,
the synth must generate frequency steps of about 9uHz at 9 GHz and
hold them for at least one second between measurements:
http://www.boulder.nist.gov/timefreq/cesium/fountain.htm
That must be some synthesizer - maybe it needs a NIST-7 to drive
it. Definitely not a weekend project in the basement
Regards,
Mike
