new hybrid batteries and overcharging
  • Thread starter john d hamilton
  • Start date
john d hamilton
Have just bought the latest type of rechargeable *Hybrid* batteries from
Maplin, made by Uniross, called Hybrio. (also Argos are now selling them
made by Sanyo).
They are supposed to have the advantage over Nickel Metal Hydride in that
they don't have the 'memory effect'. Also the advantage of the Alkaline, in
that they dont self discharge at quite a high rate when not being used.
The charger I have is an Energiser designed for Nickel Hydride batteries and
which indicates when a battery is fully charged, by the charging light going
off. But when putting in the Hybrid batteries the light does not go off.
Is there an harm done to these hybrid batteries if they are overcharged?
W
Whiskers
["Followup-To:" header set to 24hoursupport.helpdesk.]
Uniross's European website makes no mention of "Hybrio" batteries, but the
US website does - describing them as NiMH type. That site also offers
suggested 'charge times' using a variety of (presumably Uniross-branded)
chargers. For AA size 2500mAh, the longest time (presumably using the
simplest charger) is 30 hours.
Maplin's web site is as un-informative as usual.
<http://www.batterylogic.co.uk/hybrio.htm> say that these batteries "can
be recharged in /any/ NiMH battery charger".
I think that if your charger has an automatic cut-off calibrated for NiMH
cells, you should be safe enough - but don't leave batteries 'on charge'
indefinitely. There may be more information in the packaging of the
batteries you have, or in the packaging of chargers being sold for use with
such batteries.
Al Bundy
made by Sanyo).
If the light doesn't go off, they probably are charging. You could put
a meter in series with the batteries and check the charging rate after
a given charging period. You could check the charging rate at the
beginning and estimate the needed charging time so you could remove
them. With a VOM, you could also check the top voltage of the cells
before and after a period of time to verify the charge level. For
something simple, when they are overcharging, the battery will begin
to get warm or even hot. I can tell you from experience that a battery
can explode while charging. Lithium cells are more prone to it though.
I have not had a NMH type explode.
E Z Peaces
William said:
Who knows? HAVE YOU ASKED THE MANUFACTURER? No, of course not. That's too
much trouble, isn't it?
Good grief. Do you expect the people in this group to have detailed
technical information about about a new product?
By the way, I've not heard of NiMH cells suffering from memory effect.
NiMH cells have done very well for me, using a fast charger with a light
for each cell. After ten years, all twelve still hold a charge for weeks.
If more than one cell is charged on the same circuit (the same indicator
light), the charger should shut off when the first cell is charged.
With each charging cycle, the state of charge of the lowest cell may be
lower and you'll get less service out of the set of batteries. It could
seem like memory effect. The solution is the same, to drain each cell
and then charge.
O
OG
made by Sanyo).
in that they dont self discharge at quite a high rate when not being used.
and which indicates when a battery is fully charged, by the charging light
going off. But when putting in the Hybrid batteries the light does not go
off.
Have you used them yet or are you putting them in the charger straight from
the box?
If they are new they will be fully charged already. My understanding is that
the 'sensor' for detecting full charge is the drop in current when the cell
goes from 'active charging' to ' fully charged'**, so it suggests that you
are probably currently 'over'charging them.
Let them run down and then try again. Calculate the approximate charging
time and start charging so that you can check if the charger light goes out
within an hour or so of the expected time.
**I'm not an expert on this, so I'm happy to be corrected on the mechanism
for detecting full charge.
john d hamilton
Would it be to much trouble to identify the specific charger?
Many thanks to all. (except possibly Mr *Moody* Sommerwerck) The charger
is Energizer, Model; 'Compact Charger' (no serial numbers on it).
E Z Peaces
Of 13 user reviews at amazon.com, 11 disliked it.
E Z Peaces
William said:
How do you define "overcharging"? Switching to a trickle charge at the end
of the charge cycle is, technically, overcharging, but no one considers it
abuse.
In 1975 my station got a hand-held communications radio with a NiCad
battery. The radio hung in a charger that would switch to a trickle
charge when the battery was charged. That would have been ideal for a
lead-acid battery, but in a matter of weeks the NiCad would no longer
take a charge. The boss contacted the battery manufacturer and learned
that NiCads should not be left on a trickle charge. Nobody considers it
abuse because it's not intentional misuse, but trickle charging is harmful.
I began using aa NiCads in 1981. They were supposed to be good for 500
charge cycles. Within about 50 cycles, their self-discharge was so high
that they would go flat if not used within a few days. Eventually they
wouldn't charge at all. I bought a lot of them for 17 years because I
found them more practical than alkalines even if I got only a fraction
of the advertised service life.
Then I tried a set of NiMH cells along with a microprocessor-controlled
500ma charger. They performed so well that I bought many more. After
ten years, all my NiMH cells will hold a charge for months. That
charger would also work for NiCads, and I discovered that they, too, had
outstanding service lives if fast-charged.
A big killer of nickel cells is internal salts. They allow electrical
leakage so a cell won't hold a charge long and eventually can't be
charged at all. These deposits increase during trickle or C/10 charging
but apparently not with fast charging.
Tim Forcer
made by Sanyo).
Err, no. The claimed advantage is that their self-discharge rate is
extra low. Therefore they are sold in (allegedly) "charged" state, so
can be used straight out of the pack. After use and recharging, they
will allegedly still be holding a fair chunk of usable charge even
after many months of storage.
Also the advantage of the Alkaline, in that they dont self
Alkaline batteries are primaries, not rechargeable (at least, not with
great success / reliability / amount of recharge), and have
exceptionally low self-discharge rates, particularly when stored
unused.
My experience of Hybrios is that they aren't _much_ better than
standard high-capacity NiMH. Also, a significant percentage have
proved to have lower-than-nominal capacity, which has been a right
nuisance at times, and led to me checking open-circuit cell voltages
and sorting the not-very-good cells apart from the rest of the
collection.
I am trying not to rely on Hybrio's supposed long-storage life, and to
carry a spare set of cells at all times. Where I might expect to
depend on full (or full-ish) charge (full day's GPS hiking, camera
flash to be used at a wedding), I now always replace with fresh.
Others may have different experiences, and be completely delighted
with their Hybrios. This is just my experience of five packs of 4*AA
and three of 4*AAA. I charge in a Uniroos fast charger, which handles
each cell individually (these chargers are, IMO, much preferable to
the majority which force charging in pairs or quads), and the LEDs
change from flashing to steady at different times, which is partly due
to differences in the four charging circuits, but can also indicate
significant differences between cells. Obviously, the charger was a
really good one, because they stopped making it. But at least one of
Maplin's high-rate chargers operates cell-by-cell.
Other manufacturer/tradenames for the technology are:
Sanyo Eneloop
Panasonic Infinium
Vapex Instant
Hope this helps.
Al Bundy
There are ways to burn off those salts. I suppose it might be done
with a well designed apparatus to gain a bit more life from a dead
cell, but not economically practical. For emergency purposes or as an
experiment, one can "tickle" the cell with a high voltage. I have even
used 120VAC from the wall socket. This is not for the feint of heart
and I would not advise even experimenting without proper eye and other
protection. A 12VDC battery applied to a 1.5VDC cell might be held
for about a second and no more.
Rob Morley
Forward or reverse polarity?
E Z Peaces
In 1982, first time I saw self-discharge progress to a full short, I
zapped it with a capacitor charged to 170 V. It would take a charge
after that, but self-discharge was still high. I decided fixing shorted
NiCads wasn't worth much.
U
UCLAN
collection.
Sanyo Eneloop
Panasonic Infinium
Vapex Instant
There are a dozen or more manufacturers of low self-discharge NiMH batteries.
I use Kodak brand LSD NiMH AA cells in my AA flashlight, remote controls,
cordless mouse - just about everything that used to take Alkaline AA cells.
They've been in these devices for 5 months now without the need to recharge.
The only place I use Alkaline AA cells now is in my smoke detector and weather
sensing equipment. I'm sold on this type of battery.
E Z Peaces
Dave said:
During the normal charging cycle (when they're still accepting
charge), NiCd batteries do not heat up very much at all... the
electrochemical process in these batteries is said to be endothermic
during charge acceptance. The cell's terminal voltage rises slowly
during this phase of charging. Once the plates are fully charged up,
the electrochemical reaction changes, and a secondary reaction
develops which releases the energy as heat... and so the NiCd cell
heats up significantly. As a result of the change and the heating,
the cell's terminal voltage stops rising, and actually drops
significantly. This reversal of the voltage curve with time isn't
hard to detect, and most NiCd fast-chargers seem to use a "negative
delta-V" detection circuit to determine that the cell has reached full
charge and to shut off the current (or drop it to a trickle).
NiMH cells behave a bit differently. They do warm up somewhat during
the main phase of charging - the electrochemical reaction is
exothermic. Like a NiCd, their terminal voltage rises slowly during
the charge cycle. Also like a NiCd, when they reach full charge they
start dissipating most of the incoming charge energy as heat, and (in
a fast-charge scenario) they can get quite warm quite quickly.
However, the effect of this on their terminal voltage is a bit
different... it stops rising, but it doesn't begin to fall
significantly until you've gone pretty far past the full-charge point
and gotten them pretty hot... and the manufacturer data sheets I've
read say that this degree of overcharging will shorten their life
appreciably.
So, the manufacturer data sheets I've read recommend using the
temperature rise (absolute and/or delta-temperature-over-time)
directly, using a thermistor, as the primary means of detecting full
charge in a NiMH. Zero-delta-V-over-time makes a good secondary
shutoff mechanism, and a timed shutoff for safety is also recommended.
I have two chargers designed to charge AA NiMH in three hours or less.
I wish they sensed temperature, but it seems they work strictly by
voltage changes.
The first one was designed for NiCds as well. I don't recall any
trouble with NiCds, and what you've written may explain it. With NiMH,
each charger has occasionally stayed on longer than expected, and I
removed the cells because they felt hot. I haven't seen any signs of
damage from these incidents.
Before I bought my first NiMH cells, I looked at data published by an
amateur photographer using several brands of cells and more than one
charger. Sometimes when he took pictures he would find that a set of
cells hadn't taken a normal charge. I think that's a drawback in
charging more than one cell in series in a circuit designed to shut off
when a cell is charged. Even when each cell is charged in its own
circuit, I think gas bubbles formed in a cell during charging may cause
a voltage fluctuation that may shut off a charger. I wonder if that
happens more often with new cells.
U
UCLAN
I only use Ray O Vac alkaline batteries.
Some of us are more financially conservative and environmentally savvy.
How do you dispose of your alkaline batteries? It's against the law to
just throw them into the trash here in California.
I have a lot of Eveready rechargable batteries and the proper Eveready
battery gizmo recharger here.I am too lazy to fool around with that
stuff all the time, unlless a long power outage occurs.I can use one of
my inverters and charge those batteries up from one of my van batteries
if I need to.
cuhulin
PeterD
Which goes counter to what the trash is for, too...
Then again, it's California, where *everything* has been shown to
cause cancer and must have a warning.
U
UCLAN
Nah, we just don't like to pollute our ground water.
