Newb needs help!
randim
Jan 19, 2005
4
Hi everyone,
I'm trying to control a relay using a 68hc908 Microcontroller.
My relay draws 0.28A at 12V while my Microcontroller gives only 5V.
I'm thinking of using a seperate power supply for my relay and the 5V of the microcontroller to control the relay.
My question is, which type of transistor can i use as a switch for the relay... Any suggestions of common transistors that could be used??
Do I need Resistors or anything to protect the microcontroller from getting fried from return current... Or can i just use the transistor directly with the power supplies and the relay??
I'm not sure where to start any help would be great!
Alun
Tr1 can be:
BC337
BC338
BC547
BC549
BC550
BF483
BF485
BF487
2N2222A
2N3904
Any low-power NPN transistor will work.
D1 is any low-power diode rated to more than 30mA
audioguru2
Apr 6, 2004
12,026
Hi Alun,
Many of those little transistors have a maximum rating of only 100mA.
Many also have a very low current gain of only 40 with a 288mA collector current, so the value of your base resistor is much too high. I don't know if the microcontroller can output 5mA to drive the base of a transistor. Maybe a darlington transistor or Mosfet should be used.
