Noise generator
papele
Feb 21, 2023
8
Good evening I have to build a uhf noise generator for tv systems. I'm looking for a pattern with bfr 91. you give me a na no.? Thank you. .
Delta Prime
Jul 29, 2020
2,996
More information is needed.
Are you trying to down convert amateur television broadcasting signal into the UHF tv spectrum.If So than
Only a 625 line television would work .
Also,., Are you trying to make the noise generator amplifier with the bfr 91 transistor?
I think that's older than 741 op amp.
papele
Feb 21, 2023
8
no to test TV antenna systems. it must generate a constant gain signal on the entire uhf dvbt band.
Delta Prime
Jul 29, 2020
2,996
That's how power amplifiers normally work. Flat frequency response over the entire bandwidth, ideally. What kind of noise would you like...white noise? pink noise? blue noise?
TDE800UHF is a broadband UHF high power amplifier, based on BLF888A LDMOS device in a SOT539A ceramic package. TDE800UHF works in AB class and it is able to cover the whole frequency band 470-862 MHz
Delta Prime
Jul 29, 2020
2,996
pattern with bfr 91
You have to be a little bit more forthcoming you have to volunteer the information regarding your specific criteria. Would you like to buy it off the shelf or would you like a schematic with the transistor using the transistor bfr91.
