Noise generator
laydinata
Oct 28, 2005
12
    I want to make noise generator. It effects a walkie talkie and it uses 446 MHz.  walkie talkie has  8 main channel and 38 sub channel with ctcss. I want to effect all sub channel with main chennel.(ex:1.0 effect to 1.23)
Alun
Do you want a jammer?
You might need to add a buffer amplifier to minimise frequency drift but this should work, it should be fairly easy to tune to 446MHz, I've used it between 300MHz and 2GHz.
laydinata
Oct 28, 2005
12
I don't want make jammer. Iwant to effect all channel on walkie talkie or effect sub channels from self main channels. If I make noise genarator that is work 70 Hz between 260 Hz than apply main channel, I guess it will be success. What is your opinion? And have you any noise genarator schem.?
