I have the rca running down one side of the car and the power 0agu and remote cable down the other side, the head unit is grounded to the chassie not using the orig ground cable, the amps are both ground in the same place next to eachother with 4agu cable, the noise comes without the headunit turned on and its a whistling noise, also i can hear the changing when i indicate, (louder, quieter) ive tried changing the gains and it worked but the audio was almost off, no speaker / audio cable is near the power cables, not sure if its the spark plugs/ alternator/ or distro cap, ive changed the ht leads and its still noisey.
Any suggestions, i have a turbo pac 1 line driver on, what was inducing alot of the noise but as its only small amperage i put a suppressor on that and that cured that. but when i unplug that from the amps its still there, what leads me to beleive i need a suppressor on the main power from the battery, whats the changing of the caps on the alternator, can you divulge more on that one?
thanks
