non stepper motor controlling bridge problem
reko
Sep 20, 2006
10
Hey everyone well Audio Guru u helped alot in the sensors topic i would like to ask again for help on a certain subject i found all of u guys making a hell of a discusion about well
I was planning on controlling a dc motor with brushes and commutator to work with atmel at89c2051 mcu (Using pulse width modulation) well i got everything from the tutorial u linked here about the pwg through a bridge to control motor and btw the code there is simple i am a computer science student so i know about it the problem here is that i planned to use the l293d which is equipped with spike-protecting diodes and rated 600 mA per channel but the only bridge i managed to get is a l293B which isn't equipped with the diode and also rated 1A per channel that could be a problem so my question is (Is it possible to use that bridge with a dc non-stepper motor or what?)
P.S:Audio guru u really helped last time i hope u do this time :)
audioguru2
Apr 6, 2004
12,026
Its datasheet shows where to connect external diodes and how it is used with DC motors having brushes and a commutator.
If your motor draws more than 1A when starting, working hard or is stalled, then the IC will make lots of smoke.
reko
Sep 20, 2006
10
thanks man but what diode should i use can i use the ln4004 ??
here's the schematic for the circuit as u can see the bridge is l293D which is unavailable as i said before and there's no hope i will find it
audioguru2
Apr 6, 2004
12,026
A 1N4004 is a rectifier diode for 50Hz or 60Hz and is very slow. PWM at high frequencies needs faster diodes. I don't have a list of fast diodes. I need one also.
reko
Sep 20, 2006
10
what about ln4448 diode i guess it's fast enough (What is in mind??)
hotwaterwizard2
Jan 8, 2004
2,022
Would it be possible to use this IC to drive large Transistors like a 2N3055 so the circuit can handle Large loads?
http://www.cse.cuhk.edu.hk/~khwong/ceg3430/mrobot7.pdf
hotwaterwizard2
Jan 8, 2004
2,022
Search Results
L293B and L293E
http://www.st.com/stonline/books/pdf/docs/1328.pdf
L293D
ST Datasheet
http://www.st.com/stonline/books/pdf/docs/1330.pdf
TI Datasheet
http://focus.ti.com/lit/ds/symlink/l293d.pdf
App Notes
http://msgroups.tech.northwestern.edu/dc/dc99/docs/l293eapp1.pdf
http://www.st.com/stonline/products/literature/an/1675.pdf
Other Info
http://www.dprg.org/projects/1998-04a/
http://www.seattlerobotics.org/encoder/may98/steppers.html
http://www.cs.uiowa.edu/~jones/step/circuits.html
http://www.stanford.edu/~pjc30943/school/ME218%20labs/KrisPaulSal%20-%20Lab%208%20Report.doc
http://www.me.umn.edu/courses/me2011/robot/technotes/L293/L293.html
reko
Sep 20, 2006
10
thanks guys i found the l293D whixh is 600mA output and my motor is 500 mA so i guess it's almost okey to use that bridge directly
