Norbit Logic
I
Iain Wilkie
Hi All,
I have an old old unit I am trying to fix. I need info on one of the
parts...
looks like a BIG DIL IC, I believe it is what is called "NORBIT"
The number on it is 4NOR60. Just need the pinout and fuctionality.
Thanks in Advace
Iain
http://www.wilkie-electronics.co.uk
Wilkie Electronics
16, Muirhall Terrace
Perth
PH2 7ES
Scotland
United Kingdom
Tel/Fax +44 (0)1738 621492
Ross Herbert
Hi All,
parts...
Thanks in Advace
Iain
NORBIT technology was developed around the 1960's by Philips. I seem
to remember it comprised a family of "industrial strength"
semiconductor modules intended to be used in process control
equipment.
N
N Cook
equipment.
There is 20 page chapter on the Norbit family in a 1967 Philips databook in
my library. My email address off the URL below
N
N Cook
Iain Wilkie said:
Hi All,
parts...
Thanks in Advace
Iain
Wilkie Electronics
Perth
PH2 7ES
Scotland
United Kingdom
book contains pinout of dual quad input nor package, 2NOR60,17 pins yes 17,
not the 4NOR60, how many pins ?.
You are aware they use 24volt ?
N
N Cook
A 1971 Philips book has extended range of Norbit series, 100 pages
4NOR60 is 17 pins, quad 2 and 3 i/p nor , obscure numbering pattern, maximum
30V supply and permisible range on i/ps -24V to 90 V.
Viewing package on top with 9 pins on top
and 8 pins below, starting pin 1 top left and going around clockwise
1,2,3 i/p nor gate 1
4 output 4
5 out 2
6,8 i nor 3
7 supply for 1
9 common 0V
10,11,12 i nor 2
13 o nor3
14 o nor1
15,17 i nor4
16 supply nor 2,3 ,4
for any other info, a matter of photocopying
N
N Cook
Iain Wilkie said:
Thanks for all the help.....now have the info I need
Iain
Wilkie Electronics
Perth
PH2 7ES
Scotland
United Kingdom
correction to pinout number pattern.
start top left number 1
then bottom row start at left with number 10
