Old Betamax channel indicator lights, not LED.
Sparklezap
Mar 5, 2016
Hi. I've been trying to find these bulbs, no find. They look just like a NE-2 except they are white. They light up a light green color. I use an 82k-100k resister on 120 volts. I've had them last for at least 20 years! Any input?
Minder
Apr 24, 2015
3,561
A mixture of Neon and Krypton will glow green on a Neon lamp, if they are AC fed then that is what these are, I suspect you may have a problem getting BetaMax parts!!
M.
73's de Edd
Aug 21, 2015
3,730
Sir Sparklezap . . . . .
Get ready to have cornered the US market on them.
As this should be a lifetime supply for you . . . . . ..
http://www.ebay.com/itm/20pcs-Green-4mm-Neon-Light-Bulb-Indicator-4X10mm-Lampada-Lamp/252285177923?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=4754e5f396a44ce3940491142130feaf&pid=100005&rk=1&rkt=6&sd=252285177925
In addition to their gas fill mix, they are also utilizing a fluorescent coating for even greater color enhancement.
There is further confirmation, by these additional color offerings . . . . . . with the bare glass units being specified as "RED" . . . . . . but, assuredly being ORANGE.
http://www.ebay.com/itm/20pcs-Each-RED-Green-Blue-Mix-Bulb-Indicator-4X10mm-Lamp-Neon-Light-Lampada-New/252285177924?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=32e920aced284552a49acec0ce202c3b&pid=100005&rk=4&rkt=6&sd=252285177923
73's de Edd
Sparklezap
Mar 5, 2016
M.
Thank you so much to Id these. NE-2G. Many are discontinued as I look for them. But just got a post below for a good deal. I learned a lot from your input. Thanks.
