Old magazine series 99 IC projects
ratstar
Aug 20, 2018
485
In the 1979 one, I see a gizmo for a bar graph, and someone needed one for his water tank not long ago. =)
It works with a strange technique of dropping voltage through diodes, but I dont see how it works entirely. Its actually an ADC! but you need one bar per bit, not one bit per power of 2 of the result, goes to show if all you need is 8 bit resolution ADCs sample as fast as you want, as long as you put the full 256 lines down.
bertus
3,842
Did you read the text of the led bar graph?
When turning up the voltage, led 6 will be on first, then about 0.7 volts higher led 5 will turn on etc.
Bertus
ratstar
Aug 20, 2018
485
I see, I was thinking it was a current dependant input! i see now. cool.
You can exchange the diodes for voltage dividers, if your short on semiconductors. :)
So does that mean you just put a current divider instead of a voltage divider you get the current version!?
Nanren888
Nov 8, 2015
622
Diodes used to set voltage thresholds is not an uncommon technique.
Here it would give a soft turn on, for each LED, I guess.
256?, OK :) with 256 LEDs, maybe 32,768 diodes, about 150 volts and 256 resistors, ratings for that voltage & quiite a lot of current.
ratstar
Aug 20, 2018
485
Pure Parallel does increase power requirements - but it would potentially give you sub pico-second sampling, if you handled all the other problems, which I'm not aware of yet.
TCSC47
Mar 7, 2016
148
Love these 99 cct books and others like them. When I was an apprentice and we were being taught valves (It was the 60s!) I got hold of a Practical Wireless, cct pocket booklet. I spent a lot of my time knocking up the transistor ccts and learning from them. Didn't get very good marks from my supervisors, but I found I knew a lot more about transistors than any of my apprentice colleagues.
TCSC47
Mar 7, 2016
148
Maybe they were jealous.
No, I just didn't realise that I was supposed to do as I was asked to! You get wallys like me everywhere! Lol! Took me a while to figure this out. Mind you it enabled me to walk straight into a job after my apprenticeship.
