AprilSteel
- Feb 2, 2017
- 111
- Joined
- Feb 2, 2017
- Messages
- 111
I have a few of these kits , that mostly run OK however I have one with a problem which I can't find yet.
It blows the chips .
If I put new chips in it and connect the battery first then the panel everything seems fine.
If I take the battery leads off and put them on another 12 Volt battery there is a spark and it takes the chips with it . I should say chip as its the 4011 chip that goes mostly.
Its called K008E Solar Charger/regulator put out by Oatley Electronics
I've put a circuit below and would appreciate your thoughts on what might be happening.
