Hi, I have a old Triumph motorcycle. I am now attempting to wire it up to charge battery. The Generator checked out okay by the specs from a shop manual. The regulator did not. The generator is a six volt d.c. However it puts out nearly 20 volts @ high RPM when I jump the field wire to the generator output wire.. The circuit is 6 volt Positive ground. My first question is, can I use a 12volt battery,lights and regulator? Will a 12 volt battery harm the generator? Thanks, If I get an answer to this I'll move on to question #2!
