In a previous post, I asked about designing a controller to regulate the temperature of a small tank of water.
Ante suggested using a triac to control power sent to the heating element. After some reading, I also agree that this is a good technique; however, I haven't been able to find any circuit examples on the web.
My problem seems fairly simple. I have an aluminum tank with a flexible heating element wrapped around the outside surface of the tank. I would like to set a desired temperature using a potentiometer. I have a temperature sensor IC's that measures degrees Fahrenheit (10 mV per deg F). I put the IC in some copper tubing and sealed the end, making a temperature probe. This probe will be submerged in the water tank. I figure that a couple of comparator circuits could be used to compare the temperature from the probe with the desired setpoint and these comparator circuits could then control voltage to the gate terminal of the triac.
Anyone know of an example that uses a simliar technique?
The triac I have is NTE5629 rated at 400V and 4A. (Here's the datasheet http://www.nteinc.com/specs/5600to5699/pdf/nte5629.pdf). The triac came with a mica washer, which I assume goes between the metal part of the triac and the heat sink.
Thanks in advance for any help.
Darrin
Darrin
