op-amp low frequency pulse generator
walid1
Jun 27, 2004
749
I understand the 555 timer IC when used in its astable mode as an oscillator, but the one shown below i need some help in:
(1) how this oscillator work?
(2) the function of the diode?
(3) how to choose the components values to achieve some freq.?
(4) What the formula used to calculate the freq.?
(5) Can I replace Q1 with a NPN one?
Note that bat = 6 v and IC = LM393
Thanks to everybody
audioguru2
Apr 6, 2004
12,026
Hi Walid,
An LM393 isn't an opamp, it is a dual comparator. A comparator oscillates at a high frequency if it has negative feedback.
Its pin 4 needs to be grounded.
It is a Schmitt-trigger oscillator. Its pin 5 is pulled up to about +2.7V and down to about -2.7V when the output toggles. The voltage at pin 2 is delayed by C2.
You calculate its frequency by figuring how long it takes for R4 and R5 to charge and discharge C2 to the +2.7V and -2.7V thresholds, for each half-cycle, then add the half-cycles.
The diode makes C2's negative charging time short, because then the diode is forward biased and R5 is put into the circuit.
An NPN transistor can be used if the comparator's output has a pull-up resistor for its base bias current. The comparator doesn't have a push-pull output like an opamp, just the collector of an NPN transistor that can turn-off the base of the external NPN transistor.
walid1
Jun 27, 2004
749
Hi audioguru, thank u very much for your kind answer.
(1) pin 5 always connected to the voltage divider formed by R1 and R2 and so it is always at 3v potential, correct me.
(2) How u reach these numbers, +-2.7v
(3) What the values of the o/p at pin 7?
It is the first time for me to hear about negative charging!
What is a pull-up resistor and what it do?
Than u very much
audioguru2
Apr 6, 2004
12,026
No. When the comparator's output is at +9V, R3 pulls pin 3 to a positive voltage. When the output of the comparator is at -9V, R3 pulls pin 3 to a negative voltage.
Actually, it is +3.0V and -3.0V because the output transistor of the comparator doesn't have an emitter-follower loss like opamps. R2 goes to -9V. Both R1 and R3 are at +9V. The 18V is divided by 3 so pin 3 is 6V less than the positive supply. The opposite occurs when the comparator's output is at -9V.
Pin 7 swings almost to +9V and almost to -9V.
You have a negative supply. I didn't notice that C2 connects to the negative supply instead of to 0V which is more common, then C2 is charged positively slowly by R4 and is discharged quickly by R5 in parallel with R4.
An NPN transistor with its emitter connected to -9V needs a positive current feed to its base for base current. The output of the comparator doesn't have anything to provide a positive current, so a resistor is needed from the base to the positive supply. It is called a "pull-up" resistor.
walid1
Jun 27, 2004
749
Hi guru, thank u very much
no it is 6 volt (4 x 1.5V batt), the +ve terminal is 6V and the -ve terminal is 0 V.
From where u get the + and - 9 volt
u want to say that a "pull-up" resistor connect the point to +batt and the a pull-down resistor connect a point to ground
audioguru2
Apr 6, 2004
12,026
Sorry, Walid, I didn't notice your 6V battery. Here is my reply corrected for a 6V battery. The negative of the battery is the circuit's "ground".
Quote from: walid on January 12, 2006, 12:01:46 PM
No. When the comparator's output is at +6V, R3 pulls pin 3 to a more positive voltage than 3V. When the output of the comparator is at ground, R3 pulls pin 3 to a more negative voltage than 3V.
Quote
Actually, it is +4.0V and +2.0V because the output transistor of the comparator doesn't have an emitter-follower loss like opamps. R2 goes to ground. Both R1 and R3 are at +6V. The 6V is divided by 3 so pin 3 is 2V less than the positive supply. The opposite occurs when the comparator's output is at ground, pin 3 becomes 1/3 of the supply above ground, which is 2.0V.
Quote
Pin 7 swings almost to +6V and almost to ground.
walid1
Jun 27, 2004
749
hi audioguru
I think that u mean pin 5 not pin 3
You may mean the internal (inside the IC) transistor.
This is OK, i calculate and understand it but i have question:
now let the o/p at pin 7 is 6volt then the voltage at pin 5 = 4v, if pin 6 is at ground, the o/p at pin 7 will remain at 6v. to change this o/p, pin 5 voltage must be less than pin 6 (5 more -Ve or 6 more +ve).
can u, please, tell me more about this mechanesim of oscillation.
thank you.
audioguru2
Apr 6, 2004
12,026
Oops, yes.
Yes. The output transistor inside the comparator is an NPN transistor with its emitter at the negative supply and its collector at the output pin.
Pin 6 never gets to ground. C2 charges and discharges between 2V and 4V.
R3 causes positive feedback for a snap-action of the comparator with hysterisis.
With pin 7 at 6V then pin 5= 4V. Pin 6 is somewhere between 2V and 4V and C2 is charged by R4 until its voltage is 4V. When pin 6 tries to go more positive than 4V, the high gain of the comparator causes its output at pin 7 to drop. With pin 7 dropping, R3 also causes the voltage at pin 5 to drop, which speeds-up pin 7 dropping until pin 7 is at ground, pin 5 is 2V and R5 in parallel with R4 begin quickly discharging C2. When pin 6 tries to go lower than 2V then the high gain of the comparator causes pin 7 to rise. With pin 7 rising, R3 also causes the voltage at pin 5 to rise, which speeds-up pin 7 rising until pin 7 is at 6V, pin 5 is 4V and R4 slowly begins charging C2 again. ;D
walid1
Jun 27, 2004
749
Hi audioguru
First thank you very much for your time with us
I disagree, long time ago we have taught that caps are approx. short circuit during the charging or discharging process, so it connects pin 6 to ground...
What u mean by snap action and hystreisis, i know that snap is a very quick and high voltage pulse.
Now I have more questions like:
(1) Why the designer did not use another diode in series with R4 to make the discharge process only through R5, since R4//R5 approx = R5
(2) From your point of view, what the modifications that must be done to the circuit to work more efficient with less components?
thank you
indulis
Nov 21, 2005
488
Without going into the differential equations, the solution and general form for charging is:
Vcap=Vapplied*(1-e^-t/RC)
and for discharge is:
V=Vcap*(e^-t/RC)
on the discharge, don't forget to include the forward voltage of the diode.
audioguru2
Apr 6, 2004
12,026
You were taught wrong. Even the main filter capacitor following the rectifier in a power supply connects to ground and is continuously charging and discharging. It doesn't short to ground.
A capacitor has a low reactance at high frequencies, not a low resistance.
Snap action is quick (without a high voltage). Look-up hysteresis in a dictionary or on Google.
Another diode won't make any difference and isn't required.
I might use a Cmos 555 timer IC to replace the comparator but it costs more. Then R1, R2, R3 and R6 aren't required. A Cmos Schmitt-trigger inverter would also make a simple and cheap pulse generator.
indulis
Nov 21, 2005
488
He wasn't "exactly" taught wrong, you just have to remember the conditions under which it is true!! Take a simple series RC circuit (no initial conditions i.e. 0 volts on the cap)with a DC source and a switch. If you close the switch at time "zero" the capacitor at that instant indeed looks like and behaves like a short!!!!!!! If you have a charged capacitor and you apply a transient, you would model it as a discharged capacitor in series with a voltage source that is equal in value to the capacitor voltage prior to the transient!!!
In this case such a lage value for R4 it doesn't matter much, but a diode in series would block R4 from being in the discharge equation. If R4 was 100K, IT WOULD MAKE A BIG DIFFERENCE!!!
audioguru2
Apr 6, 2004
12,026
Hi Indulis,
Of course the capacitor's voltage is at ground the moment power is applied to the circuit, then the comparator waits an extra amount of time for its voltage to reach the Schmitt-trigger threshold voltage. It is like the famous 555 type of 1st half-cycle time extension.
Speaking of the 555, I forgot to mention that it wouldn't need a diode for it to have a long capacitor charge time and a short discharge time.
indulis
Nov 21, 2005
488
"Of course the capacitor's voltage is at ground the moment power is applied to the circuit...."
That's not the point.... you said, "You were taught wrong." He wasn't, and I just gave a simple example of how a capacitor can "appear" to look like a "SHORT" (short being the key word) to ground. While applying principals of transient circuit analyisis, capacitors become "SHORTS" with a series voltage source and inductors become "OPENS" with a parallel current source. Walid's application of those principals just wasn't 100% correct.
audioguru2
Apr 6, 2004
12,026
Whatever teaching-about-capacitors method Walid's teacher used that made him think that capacitors are a DC short is wrong.
Maybe the teacher was completely mixed-up and was really talking about inductors.
Maybe Walid is completely mixed-up about capacitors and inductors. ???
indulis
Nov 21, 2005
488
Mr Klampfer
Explain to me what you don't understand about the following statement?
"While applying principals of transient circuit analyisis, capacitors become "SHORTS" with a series voltage source and inductors become "OPENS" with a parallel current source. "
audioguru2
Apr 6, 2004
12,026
Indulis,
I understand that a transient contains high frequencies and that the reactance of a capacitor is low (like an AC short) a high frequencies. It isn't a DC short.
I don't understand how an inductor can be "open" when fed from a DC current source.
An inductor resists the flow of high frequency current due to its reactance rising at high frequencies. At DC an inductor is a short.
walid1
Jun 27, 2004
749
Hi audioguru
yes this is true, i hope that you always teach me.
indulis
Nov 21, 2005
488
First, let me reiterate that the concept I am referring to, is applicable to transient circuit analysis (not steady-state), and by definition only holds true for the instant in time that you are interested. Again, take a simple series RC circuit with a source and switch. To make it simple, let
