OpAmp Input Stage with different voltage ranges
Marco T.
Hallo,
I must develop a system that should accept at the input the following
voltage ranges:
0 5v
0 10v
0 15v
I thought two chances:
1) Using a voltage divider where I could choose the couple of resistor using
2 multiplexer.
I connect every resistor to input of a mux and I configure the two mux using
a couple of jumpers.
Then I connect to oupt of voltage divider a opamp voltage follower or
similar.
2) Using a programmable gain amplifier.
There are orther chances?
Any comments is very appreciated.
Many Thanks
Marco
Marco T.
Marco T. said:
Hallo,
voltage ranges:
0 5v
0 10v
0 15v
using 2 multiplexer.
using a couple of jumpers.
similar.
Many Thanks
Marco
I forgotten to say that output stage must be in range 0 5v.
mmm
If you want to use jumpers to configure the mux just remove the mux and
use jumpers to configure input topology ( or even place only needed
resistors )
input
o---R----o---o------ to OPAmp
R R
GND GND to ground trough jumpers
leave jumpers open for 0-5 range put one jumper for 0-10 two jumpers for
0-15 range
input impedance change on different range
max134 from maxim show an interesting topology for input range selector
Spehro Pefhany
Hallo,
voltage ranges:
0 5v
0 10v
0 15v
2 multiplexer.
similar.
Many Thanks
Marco
If you're using an ADC you could consider use more resolution than you
need and throw away an LSB or two for the lower voltage inputs.
If you don't mind using jumper blocks, this is pretty easy/cheap:
In Jumper position
o 1: 0~15V
| 2: 0~10V
.-. 3: 0~5V (storage position for jumper block)
20K0 | |
1 | 2 3
.--|--------. Out
| o--o--o----------------o
| o o o |
10K0 '-''-'20K0
GND
You can buffer the input and/or output if you like.
Best regards,
Spehro Pefhany
David L. Jones
Marco said:
Hallo,
voltage ranges:
0 5v
0 10v
0 15v
2 multiplexer.
similar.
Many Thanks
Marco
If you have a high input impedance and minimum settling time is
important then you might be better off having a seperate resistor
divider and buffer for each input and then have the mux on the low
impedance output of the buffers.
One fixed divider plus a programmable gain amp is probably the simplest
solution though.
Or simply a fixed 15V range and a higher res ADC as someone else
mentioned.
I think Maxim make ADCs with built-in selectable ranges like this.
Dave :)
jasen
On Thu, 27 Jul 2006 10:29:33 +0200, the renowned "Marco T."
In Jumper position
o 1: 0~15V
| 2: 0~10V
20K0 | |
1 | 2 3
.--|--------. Out
| o o o |
10K0 '-''-'20K0
GND
The third position isn't needed the jumper can be stored horizontaly
Bye.
Jasen
