Opamp offset voltage problem
Hi! I want to measure the offset voltage of an opamp. First, I
configure the opamp in an unity gain buffer and measure the output.
The offset voltage is 64.16uV. Then, I applied this voltage to the
non-
inverting input of the opamp. When I simulate it again, instead of
getting 0V at the output, I get 464.29mV. Is the setup correct? Is the
offset voltage of 64.16uV correct? Looks a bit small for an opamp.
Thanks.
Amy
* Schematics Netlist *
I_I1 0 $N_0001 DC 100u
M_M1 $N_0002 $N_0002 $N_0003 $N_0003 Mbreakp
+ L=1u
+ W=50u
M_M2 $N_0004 $N_0002 $N_0003 $N_0003 Mbreakp
+ L=1u
+ W=50u
M_M6 $N_0001 $N_0001 $N_0005 $N_0005 MbreakN-X2
+ L=1u
+ W=10u
V_V1 $N_0003 0 5V
V_V2 0 $N_0005 5V
R_R1 $N_0007 $N_0006 12.245k
M_M8 $N_0006 $N_0004 $N_0003 $N_0003 MbreakP
+ L=1u
+ W=100u
M_M14 $N_0003 $N_0006 VOUT VOUT MbreakN-X7
+ L=1u
+ W=10u
M_M7 $N_0007 $N_0001 $N_0005 $N_0005 MbreakN-X4
+ L=1u
+ W=20u
M_M5 $N_0008 $N_0001 $N_0005 $N_0005 MbreakN-X3
+ L=1u
+ W=20u
M_M15 $N_0005 $N_0007 VOUT VOUT MbreakP
+ L=1u
+ W=25u
M_M4 $N_0004 $N_0009 $N_0008 $N_0008 MbreakN
+ L=1u
+ W=20u
M_M3 $N_0002 $N_0010 $N_0008 $N_0008 MbreakN
+ L=1u
+ W=20u
V_V8 $N_0010 0 0V
V_V9 $N_0009 $N_0010 -64.16u
K
kell
Here's another way that might be more reliable.
To measure offset:
ground the non-inverting input; run a pot from the op-amp output to
ground; connect the pot wiper to the inverting input. Measure the
output voltage. Calculate offset at the input as output voltage times
1+(R2/R1), where R1 is the grounded side of the pot and R2 is the side
connected to the op amp output.
non-
Is the op amp open loop? I don't think that's how you null them out.
There are nulling cicuits here:
http://www.google.com/search?hl=en&q=op+amp+circuit+collection
K
kell
On Feb 1, 10:36 pm, [email protected] wrote:> Hi! I want to measure the offset voltage of an opamp. First, I
To measure offset:
D'oh, or just use a couple of resistors.
Jamie
To measure offset:
you know, back in the old days! i think it is the 741? pins 1 and 8
gave you nulling inputs you could put a pot on with the wiper to
- to fix that little problem. :)
