Open/Short Links request
Roger Bourne
Does anyone know of any good links that explain "design of open/short
detection" of lead bonds (of IC modules)?
What would be a good search criteria for google?
I tried "open/short design detection", "fault detection design" but I
have yet to find an article which focuses on its design.
I have my own idea of how to make a open/short detection cct, but its
mostly derived from the theory section of the manual of [Exatron's
Open/Short Tester]. It is a small section.
http://www.exatron.com/products/pdf/400.pdf
Any help will be appreciated.
Regards,
-Roger
Rene Tschaggelar
Roger said:
Once you defined what a short or open is,
then you're a giant leap further.
Then you could define maximum measurement
parameters in terms of voltage and current.
Rene
Roger Bourne
Hmmm,
A short would be an unexpected low resistance between 2 nets/lead
bonds.
But from a generic point of view, how does one built an automated cct
to detect a SHORT ? A cct that would detect shorts for more or less ANY
IC module.
Does one essentially mirror an ohmmeter's design (which is also
completly unknown to me) and measure for impedance between all possible
combination of 2 lead bonds? Impossible!
Regards,
-Roger
Jim Thompson
Hmmm,
bonds.
IC module.
Regards,
-Roger
Just define (being somewhat arbitrary)...
SHORT < 10ohms
OPEN > 1K
I once designed an alarm system that way, such that a median value was
"good". A short or an open would trigger the alarm.
...Jim Thompson
Rene Tschaggelar
Roger said:
Hmmm,
bonds.
IC module.
Basically yes. There are different ways however.
The blunt approach would be a voltage source with
current limit while measuring the current.
Define the voltage and the current limit
sufficiently small such that no damage occurs.
Another approach would be a sinewave of
sufficiently small frequency that generates a
very low voltage, eg 10mV, and measures the
current in a lock-in fashion across a burden
resistor with a gain of 10^4 or so.
Rene
