Short/open circuit detector in wall
Junjie
May 9, 2018
Hi..what sensor that can easily detect open and short circuit in walls at home except testers / multimeters .thank you
bushtech
Sep 13, 2016
1,025
If there is a fault in a cable get an electrician to pull a new cable through. Detecting the fault is just extra cost and doesn't fix it.
MicroMe
May 18, 2014
21
For detecting a break in a free cable I short circuited the far end and connected an audio signal generator to the other. Then using my hifi amp with a open ended cable ran this along the cable listening to the signal. The loss of signal at the break was quite dramatic and located within mm's.
For a power cable in a wall replacement as bushtech suggests is the best option as even if located how will it be repaired without lots of decorating. A big concern is how or why it got damaged.
kellys_eye
Jun 25, 2010
6,512
opens and shorts are rarely anywhere except at either end of the cable. If you have a problem, check at the outlet and at the fusebox. The chances of a short/open anywhere inbetween (unless there is a hidden junction box) are as good as zero.
shrtrnd
Jan 15, 2010
3,903
I think it would help if you explained exactly what you mean.
As noted in previous posts, is this for audio signals, power wiring, or something else.
I'm curious about the 'open or short circuit in a wall' question.
What kind of application are you talking about?
At least here in the US, multiple outlets are strung together from the fuse box. If one outlet is out, it could be an open at another outlet in the same string.
duke37
Jan 9, 2011
5,364
I was asked to look at a friend's mother's house. The deep freeze in the garage was live (240V) and she was complaining of the shock when she opened the lid:). I tested it with my magic screwdriverand declined to touch the freezer.
The poblem was that she had had the walls impregnated with silicone and the contractor had drilled the wall and managed to cut the earth wire and connect it to the live. A new cable was fitted.
Have you been hanging pictures or fitting shelves?
kellys_eye
Jun 25, 2010
6,512
Same here - but the faults, if any, will be at the socket plates (not withstanding anyone drilling holes or putting screws in them).
Our own installation safety instructions (UK) show the position of cable runs and it would be unusual for someone to drill or screw into a cable - basically avoid anywhere in a vertical line above the outlet and in a horizontal line between two adjacent sockets.
