Short/Open Detection Link request
Roger Bourne
Does anyone know of any good links that explain "design of open/short
detection" of lead bonds (of IC modules)?
What would be a good search criteria for google?
I tried "open/short design detection", "fault detection design" but I
have yet to find an article which focuses on its design.
I have my own idea of how to make a open/short detection cct, but its
mostly derived from the theory section of the manual of [Exatron's
Open/Short Tester]. It is a small section.
http://www.exatron.com/products/pdf/400.pdf
The dififculty I am having is with the detection of "shorts".
"Detection of OPEN pins" are RELATIVILYeasy; The ESD diode (that
protects the pin against ESD) is placed in forward bias in order to
form a current path --> If there is a current path, then there will be
a voltage drop accross the ESD diode. If the pin is unconnected (OPEN)
(e.g. lead bond is broken), then there is no current path. Hence, if
the pin's voltage is found to be at [~0.6V] or [vdd-0.6] (depends which
ESD diode is employed for the current path, top or bottom), then the
pin is NOT open. Otherwise, the pin is open; the pin's voltage will be
at a rail [vdd] or [gnd].
The "detection for a SHORTed pin" is not as simple though. As I
understand it, the method for detecting a short is basically [the
weighing/measuring of an NOT-open]. In other words if we find that the
voltage drop of the pin's ESD diode is too low, it would imply that a
second diode has joined the first one (in parrallel) and as such there
is a short.
However, the following problems come to mind:
1. All the pins of the IC would have to have the same ESD protection.
Otherwise, the circuit would require trim signals in order for pins
that are not shorted, not be detected as shorts. Also, some intelligent
entity (most probably a programmable device) would have to control the
trim signals with respect to the PUT (pin-under-test). The introduction
of non-uniform ESD protection renders the short detection fairly
complicated, at least from a initial point of view. There has to be an
easier way.
2. Fairly often, a pin is routed to several IC modules. E.g. A 512Mb
stick of DDR ram is comprised of several IC modules (if remember
correcly, there is at 9 SDRAM modules). This poses pretty much the same
problem as in 1. Some pins of the 512Mb stick will only be routed to 1
pin on 1 IC module (e.g. data signals), while others are/should/might
be shared (e.g. SELECT signals of the SDRAMs). This pin sharing will
multiply the ESD protection.
3. Assuming that all pins have the same ESD protection, how is the
"expected voltage drop of the ESD diode" to be saved, in order to be
used as a reference? Which pin will be used during the saving process?
How can it be assured that the pin will not have a short?
4.If the process is rendered automated, are there any provisions one
has to take to assure a more less speedy outcome?
Any help will be appreciated.
Regards,
-Roger
