Optical guitar pickup
moeburn1
Mar 22, 2005
4
I'm interested in trying to design an optical guitar pickup, pretty much an LED and a photocell that sense the movement of the string and convert it to an audio signal.  Unfortunately, I can't even get a simple demo to work with an LED and photocell, mostly because I have no idea how to amplify it.  Any ideas?
audioguru2
Apr 6, 2004
12,026
Hi Moeburn,
Won't the string constantly cast its shadow on the photocell, so even when it is vibrating there won't be any output?
EdwardM
Apr 12, 2005
246
Hi moeburn
I recently did some design work on an absolute angle encoder, arising out of that I looked at 'other' ways of achieving a solution.  One of these ways was to use a cmos strip or CCD sensor, there are a few companies, mainly in California which supply them and which may be a solution to your problem, I'll take a look at my notes and come back later.
Best of Luck
Ed
EdwardM
Apr 12, 2005
246
Hi
this is the sort of thing I was thinking of, a Fairchild 2048x1 pixel sensor.  Whilst many are designed for use with scientific instruments, I'm sure that you'll find others which are much cheaper and which could be used either staggered or in line to cover the full distance beneath the strings and to include pitch bending
Best of Luck
Ed
Alun
EdwardM, nice idea but what advantages does it have over a magnetic pickup?
EdwardM
Apr 12, 2005
246
Hi Alun
basically, none at all and the magnetic pickup is well proven and cheap. Using the type of thing I suggested would probably get people involved in DSP and the higher realms of mathematics.
But the original question was about designing an optical means of achieving the same thing - probably its most important outcome was a learning exercise and, don't know about anyone else but that's one of the main reasons why I enjoy this forum.
All the Best
Ed
MP1
Dec 7, 2003
3,399
Ed, the vibration of the string is the same in all directions from the core for the string frequency, which is where the magnetic pickup excels. In a visual system, you would need to take into account that when the string is plucked, it will have a sideways movement, which can be different each time depending upon who is plucking, how hard, and  possibly different from time to time. This deos not effect a magnetic pick up. Perhaps this is where your problem lies. It seems like you would also have different points of defraction/refraction of the LED where the light hits the vibrating string.
Hope it is food for thought.
MP
EdwardM
Apr 12, 2005
246
Hi MP
I'm aware of the differences between and advantages of mag pickup, if you check back the posts, what I've done is provide one possible solution to moeburns' original question and hopefully given food for thought.
? my problem?
On your point about diffraction and vertical movement, it's a good one and the cmos/ccd sensor in conjunction with DSP could provide a solution by measuring the rate of change of shadowing since the sensor is a nice mixture of analogue and digital technology.  Digital in terms of position and analogue in that an analogue voltage is produced in each bin.
All the Best
Ed
MP1
Dec 7, 2003
3,399
Hi Ed,
My post was meant for moeburn. Don't know why I put your name on it. Sorry for the confusion. Yes, it was a reply for moeburn and had nothing to do with your post about DSP.
MP
XYZVector
May 31, 2005
I have desinged a few, there is one particularly effective yet simple way to achive, the amplification you desire, but the circuit is a bit more complex. 1 instead of using a solar cell use a IR phototransistor, your sensor and pre-amplification is solved with this one little device. Second you will need to chain 6 of these photo transistors, into a 6 channel mixer, with a 50-60hz notch filter. You will hear a horrible buzzing sound if you don't use the notch filter. With a 9v batter you can acheve awesome gain, with no distortion. The talk of using CCD's are just rediculus. Most people don't realize that the string modulates the light's waveform, that is what causes the modulation in the sensor. Angle smangles they don't matter since the light will be modulated, and no matter what path it takes to the photosensor it will still be modulated. I have built this pickup for my experimental guitar, thinking I had a patentable Idea, but by the time I was old enought to file for a patent I found out that idea has been out there for 28 years before my implementation of it. However for experimenting and fun that is the way you would go about building a optical pickup, not rocket science, but just plain old good sound.
EdwardM
Apr 12, 2005
246
Hi XYZ
without going too deeply into the various points you raised, could you explain a bit more about your assertion...
Ed
Alun
I understand; if the string casts a shadow over a sensor when it's in one position then it moves it allows the light to pass in another, and it's vibrating the light falling on th sensor will be pulse frequency modulated.
Edit:
This wouldn't be of much help any way because there's more information present than just the frequency, this method neglects the amplitude. You'd have to use another method in conjunction with this to provide data about the amplitude.
