Opto-couplers in smps - part 3 (final chapter)
Steve
Hi once again,
I've find an optocoupler called TCET 1102 G.
According to its datasheet, this coupler has an Fc of 110kHz.
Datasheet: http://www.dzsc.com/pdf_down.asp?id=642422
Will this mean I may use it in my smps loop which has a unity gain
frequency of 3kHz.
Regards
Eeyore
Steve said:
Hi once again,
110kHz with a diode current of 10mA and a load resistance of 100 ohms. I suspect
you're unlikely to be using it like that.
frequency of 3kHz.
It won't have an Fc of 110kHz most likely under the conditions you're likely to
be using it I reckon.
Graham
Terry Given
Graham
wot he said. Its trivial to measure the -3dB frequency response of the
opto in your circuit; do so. That way you'll KNOW the phase shift the
opto introduces.
Conversely its astonishingly hard to measure the total loop response
unless you have a fancy wodgy. thats wy step responses are often used
(and why said wodgies exist).
you can also do this: run the smps from an isolated supply, and
completely bypass the opto. Do a step response, check its fine, then put
the opto back in and do it again. you'll pretty soon see if the opto
adds too much phase shift.
Cheers
Terry
Steve
opto introduces.
Cheers
Terry- Dölj citerad text -
- Visa citerad text -
Though it seems like a good opto for this purpose?
Paul Mathews
Though it seems like a good opto for this purpose?- Hide quoted text -
- Show quoted text -
Yes, although 100 kHz is about the usual fc for most optos operating
at around 1 mA LED bias and loaded on the phototransistor side such
that saturation is avoided. If you're connecting the LED anode to your
p.s. output without intermediate filtering, note that the frequency
characteristics of the circuit driving the cathode will not
necessarily dominate. For example, the classic TL431 integrator
driving the cathode can be understood to provide something like an AC
ground at the cathode at high frequencies, with the optocoupler then
coupling h.f. ripple on the LED anode directly to the output
phototransistor. The resulting midband rise in feedback has probably
saved more than a few designs and thrashed as many others.
Paul Mathews
Steve
Paul Mathews- Dölj citerad text -
Ok
First I thought of using an op-amp with compensated feedback for
driving the led, but
since yesterday I'll try the TL431 instead.
The opto-coupler led anode will be coming right from one of the supply
lines, through dropping resistor / zenerdiode combination.
Across the zener there's a filter cap. This will bring noise down a
bit.
To the "input" of the TL431 there are a pole-zero network and across
the TL431 there's another pole-zero network and
one slope. There might come through some h.f ripple through the
compensation components across the 431.
This would surely also increase midband feedback / lowering the gain /
cause unwanted phase shift... Oh dear.
Terry Given
Steve said:
Ok
it makes no difference if the LED is fed from the supply you are trying
to regulate.
bit.
what you have described should avoid the issue Paul mentioned.
When the opto LED circuit runs off the supply to be regulated, the
overall circuit gain is always > 1 - draw a block diagram, its pretty
clear why. Even when the TL431 is a dead short, there is always the
direct path from supply thru led and series R.
with the zener pre-regulator and associated cap feeding the opto LED,
you effectively remove this path.
there is nothing "wrong" with either approach, you just need to
understand your loop before attempting to close it. As others mentioned,
most SMPS do this.
Cheers
Terry
Steve
to regulate.
most SMPS do this.
Cheers
Hello Terry.
I get your point of the gain > 1 since the power to the led comes from
the same point as the
regulation does. If led power drops, the power will increase (since
led only will limit the pulsewidth)
But I'm little confused of the difference in using a zener pre-reg.
I see it's a parallel path across the led, but........ hmmm
Most greatful for any additional comments,
Thanks!
Regards
Stefan
Terry Given
Steve said:
Hello Terry.
just examine the maths, rather than hand-wavey arguments ;)
Thanks!
Regards
Stefan
When you write an expression for LED current, it looks something like this:
Iled = (Vout - Vled - Vk)/Rled
Vk = (Vout - Vref)*H(s)
Vk = kathode voltage of TL431, ie the error amp output voltage (I've
carefully ignored the voltage divider here). H(s) = xfer function of
TL431 cct.
when you look at the small-signal response (perturb and toss out DC &
high-order perturbation terms - IOW partial derivatives wrt Vout) Vled
disappears, as does Vref. You actually end up with:
Iled(s) = (Vout(s) - Vk(s))/Rled
this is the key bit here
H(s) = -Zf(s)/Rtop
Zf(s) = impedance of TL431 feedback network
Rtop = top resistor in voltage divider; the bottom resistor always has a
constant voltage = Vref across it, due to the magic of -ve feedback, so
it falls out of the equation. if you thevenise the voltage divider and
do the sums, you will see this happen.
Vk(s) = Vout(s)*H(s)
so you get:
Iled(s) = [Vout(s) - Vout(s)*H(s)]/Rled
Iled(s) = Vout(s)[1-H(s)]/Rled
now you see where the 1 comes from. Even when H(s) goes to zero, the 1
doesnt.
If you use a pre-regulator, it is:
Iled = (Vprereg - Vled - Vk)/Rled
and, by definition (the regulator bit) Vprereg has no dependance on
Vout, so its partial derivative wrt Vout = zero - it looks like an AC
short circuit.
you then end up with:
Iled(s) = -Vout(s)*H(s)/Rled
which will go to zero whenever H(s) goes to zero.
HTH
Cheers
Terry
Steve
Hello Terry.
Thanks!
Regards
Stefan
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
HTH
Cheers
Ok, but I'm forced to use the pre-reg since the tl431 cannot withstand
this high secondary voltage.
I'm regulating somewhere around 100V.
But when you say that gain will always be > 1 , in which frequency
does this apply?
I try to have a closed loop response unity gain frequency of 3kHz,
since Fswitch is only 30kHz due to the slow IGBT devices used as main
switches.
Terry Given
Steve said:
Steve said:
On 6 Feb, 11:16, Terry Given <[email protected]> wrote:
Steve wrote:
On 5 Feb, 16:35, "Paul Mathews" <[email protected]> wrote:
On Feb 5, 2:48 am, "Steve" <[email protected]> wrote:
On 5 Feb, 08:58, Terry Given <[email protected]> wrote:
Eeyore wrote:
Steve wrote:
Hi once again,
Datasheet:http://www.dzsc.com/pdf_down.asp?id=642422
frequency of 3kHz.
opto introduces.
Cheers
Ok
to regulate.
bit.
most SMPS do this.
Cheers
Hello Terry.
Thanks!
Regards
Stefan
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
HTH
Cheers
does this apply?
read harder. it sounds like English is not your first language.
if you use a pre-regulator (you do) then that doesnt apply.
switches.
just analyse the transfer function of your entire secondary circuit,
using much the same technique I illustrated above. Dont forget to
include the frequency response of the TL431 itself.....
or, post an ASCII drawing, and we'll help you do it.
Cheers
Terry
Steve
Steve said:
Steve wrote:
Steve wrote:
Eeyore wrote:
Steve wrote:
Hi once again,
110kHz with a diode current of 10mA and a load resistance of 100ohms. I suspect
frequency of 3kHz.
Graham
opto in your circuit; do so. That way you'll KNOW the phase shiftthe
opto introduces.
Cheers
Ok
to regulate.
bit.
This would surely also increase midband feedback / lowering the gain/
most SMPS do this.
Cheers
Hello Terry.
Thanks!
Regards
Stefan
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
HTH
Cheers
does this apply?
switches.
Cheers
No, English is not my first language, you're right, but..........
no, never mind.
I'll read harder, and try to understand.
Thanks a lot for your assistance, I really appreciate it.
Regards
Stefan
Terry Given
Steve said:
Eeyore wrote:
Steve wrote:
Hi once again,
frequency of 3kHz.
opto introduces.
Cheers
Ok
to regulate.
bit.
most SMPS do this.
Cheers
Hello Terry.
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
Cheers
does this apply?
switches.
Cheers
no, never mind.
well done, I can only speak 1.5 languages. eventually I'll be able to
have a proper conversation in Mandarin, but it'll be a long time before
I can read a newspaper ;)
IOW I'm not giving you a hard time; reading comprehension is hard
enough, but ESL complicates things further.
the info is there. seeing as ou didnt quite get it, I'll re-phrase it.
try asking this question: what is the small-signal relationship between
the regulated output voltage and the opto LED current when you replace
the error amplifier (TL431) with a short to 0V, for both the
conventional (fed from Vout) and your pre-regulated circuit?
the answer is:
Iled = (Vout - Vled)/Rled for the conventional circuit
perturbing, the small signal relationship is
iled = vout/Rled IOW its directly proportional to Vout (this is the "1")
for your circuit:
Iled = (Vpre_reg - Vled)/Rled
small signal:
iled = 0
Regards
Stefan
no worries. you should have seen the number of ****-ups I made in my
first SMPS. the best one of all was completely omitting the transfer
function of the TL431, which kinda explains why my calculations had no
bearing on my measured results. In the end I "tuned" the loop manually,
by looking at the step response and fiddling it :)
Cheers
Terry
Steve
Steve said:
Steve wrote:
Steve wrote:
Steve wrote:
Eeyore wrote:
Steve wrote:
Hi once again,
Will this mean I may use it in my smps loop which has a unitygain
frequency of 3kHz.
It won't have an Fc of 110kHz most likely under the conditionsyou're likely to
Graham
wot he said. Its trivial to measure the -3dB frequency responseof the
opto introduces.
completely bypass the opto. Do a step response, check its fine,then put
the opto back in and do it again. you'll pretty soon see if theopto
Cheers
that saturation is avoided. If you're connecting the LED anode toyour
Ok
to regulate.
bit.
most SMPS do this.
Cheers
Hello Terry.
Thanks!
Regards
Stefan
When you write an expression for LED current, it looks something likethis:
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
HTH
Cheers
does this apply?
switches.
Cheers
no, never mind.
the answer is:
for your circuit:
small signal:
iled = 0
Regards
Stefan
Cheers
If you have the time to look at it, I may upload a schematic of the
entire loop including
power circuit gain and compensation bits.
Eeyore
entire loop including power circuit gain and compensation bits.
You can't post binaries (attachments) here but if you can get access to
alt.binaries.schematics.electronics that's the ideal place for it. Or put on it one of those free
picture sharing sites.
Graham
Steve
Graham
I've got some own webspace so that's not a problem
Terry Given
Steve said:
Eeyore wrote:
Steve wrote:
Hi once again,
frequency of 3kHz.
opto introduces.
Cheers
Ok
to regulate.
bit.
most SMPS do this.
Cheers
Hello Terry.
TL431 cct.
H(s) = -Zf(s)/Rtop
so you get:
doesnt.
short circuit.
Cheers
does this apply?
switches.
Cheers
no, never mind.
the answer is:
for your circuit:
small signal:
iled = 0
Regards
Stefan
Cheers
can you email it to me? my crappy ISP wont let me see ABSE, and Im way
too lazy to figure out any other way of doing it. you can deduce my
email from the post :)
Cheers
Terry
Terry Given
thats even better. ignore my previous post then.
Cheers
Terry
Rich Grise
I have not yet met an ISP who doesn't provide a web page for each of
their customers. Somewhere on their home page, they should have
instructions on how to reach it by FTP, and so on.
I'm not using mine, because I've already got so many. You might try
Tripod, or Lycos, or Geocities, which has come to be known as Geoshitties,
but I'm sure you get the point.
Cheers!
Rich
Eeyore
their customers.
My current ISP doesn't. They just provide first class connectivity and a mail server.
Graham
