Opto-couplers in smps - part 3 (final chapter)
H
Henry Kiefer
| Rich Grise wrote:
| > I have not yet met an ISP who doesn't provide a web page for each of
| > their customers.
| My current ISP doesn't. They just provide first class connectivity and a mail server.
If it is true first class connectivity, then you can run your own server at home.
- Henry
Eeyore
Henry said:
| > their customers.
You can but it's far simpler ( for the time being at least ) to use theirs.
Graham
Steve
thats even better. ignore my previous post then.
Cheers
Terry- Dölj citerad text -
- Visa citerad text -
Hi Terry!
http://www.etanoldax.se/smps1.JPG
This link will bring you a very simplified circuit diagram made in
pure windows paint (!!)
It will give you information about power circuit gain and compensation
bits included in the loop.
My aim was to include a "double zero" at filter resonance to cancel
the phase shift caused by the LC filter.
The filter has a resonance frequency of 125Hz, I put a double zero at
153Hz.
Unfortunately I'm unaware of the ESR in the output caps. I noticed, if
it's between 50-100 mOhms, a very nice zero is introduced
which make things even better.
As I mentioned, I aim for a loop response unity gain frequency of
3kHz.
I'll be most greatful if you go through my circuit step by step to
determine loop compensation stuff.
This will be very teaching for me!
I appreciate your time and kindness in learning me this tricky things!
Regards
Stefan
K
krw
Dumb donkey, you just said they didn't support user web pages.
Sheesh!
Andrew Edge
Hi Terry!
153Hz.
3kHz.
Regards
Stefan
Hi .
To be a real help we need all the values of the components.
They are some component values that are missing. Resistors, capacitors
and looks like a zener .
Andy
Terry Given
Andrew said:
Hi .
Andy
the zener is OK. but the other side of the opto isnt there at all, and
both the zener feed resistor (so we can figure out if it can support the
opto current) and the opto LED resistor are pretty important. Rbias is
irrelevant.
As a general comment, it is common to provide the TL431 bias current by
placing a resistor across the LED. Choose it such that the maximum TL431
bias current almost forward-biases the LED (at the maximum temperature).
for a TL431 its about 1mA, which is going to dump 88mW in the zener
resistor. Then there is the opto current, which is probably a lot more
than 1mA (no way to work it out without the transistor-side circuitry).
Stefan, the basic circuit looks OK (apart from the aforementioned
things), you're certainly on the right track. you just have to include
the entire opto & SG2525 error-amp circuitry in your calcs.
BTW voltage mode is not really the best technique; current mode is
almost always better. It automatically has phenomenal line rejection,
which works on a cycle-by-cycle basis, and of course inherently has peak
primary power limiting. And it magically deals with staircase
saturation, startup issues etc.
Cheers
Terry
K
krw
Since when is a mail server anything to do with use webspace ?
The dumb donkey can't read. Hint from above: "I have not yet met
an ISP who doesn't provide a web page..." There is nothing in this
threadlet about mail servers.
Eeyore
krw said:
[email protected] says...
And I said previously " They just provide first class connectivity and a mail server."
There is nothing in this threadlet about mail servers.
I suggest you learn to read.
Graham
K
krw
Dumb donkey still can't read. The particular discussion *was*
about web servers.
Dumb donkey still cant read after the obvious has been put right
under his stupid nose.
Steve
irrelevant.
Cheers
Terry,
I've uploaded an improved schematic.
All components are now given a value, including "primary" side opto
circuit and 2525 internal error amp, though is used only as a buffer.
Best regards
Stefan
Eeyore
Can anyone else take a peek ?
Graham
Eeyore
about web servers.
I was indeed responding to the comment " I have not yet met an ISP who doesn't provide a web page for
each of their customers."
Are you blind or something ?
Graham
K
krw
Dumb donkey...
The original post (with some line wraps and a leading space to
eliminate the auto-quotation) I replied to:
Henry said:
for each of their customers.
Grease indicates that he had never seen an ISP without web service
bundled. Ok, so far?
Dumb donkey says his ISP has no web service included.
HenryK says that if it was such a great ISP you could run your own
web server.
to use theirs.
Dumber-than-Dirt Donkey says that it's far simpler to use theirs,
which he just said in a reply above, didn't exist.
Get it now Dufus Donkey? Good, you can stop running from yourself
now.
Someone is, but he ain't on this side of the great pond.
Terry Given
Eeyore said:
Graham
yes, but they'll have to have some degree of reading comprehension in
order to do so ;)
Cheers
Terry
H
Henry Kiefer
krw said:
It is really such simple to run a selfowned webserver. At least for simple HTTP. You don't need honkey-donkey SAMBA or Apache.
Updating your webspace is much simpler then. Just drag the files to the webroot directory and it is online. No ftp needed.
Try www.aidex.de It is free, small, effective. Forgive me if it is german language.
A bigger candidate is Abyss Web Server - even free and english spoken.
But you need a 24/7 online for best results and dyndns update if your IP changes. Also free.
All free and no commercial breaks - great, isn't it??
- Henry
Eeyore
Dumb donkey...
Dumb KRW.
Absolutely fine.
Dumb KRW has it right so far.
web server.
Absolutely wrong. He said server without specifying web or mail.
to use theirs.
To use their mail server rather than set up your own.
now.
I get it that you're incapable of understand what's in front of your nose.
Now grow up !
Graham
jasen
Organization: Slingshot Internet
NNTP-Posting-Host: news.tranzpeer.net
X-Complaints-To: [email protected]
can you email it to me? my crappy ISP wont let me see ABSE, and Im way
too lazy to figure out any other way of doing it. you can deduce my
email from the post :)
If you ever feel like switching ISPs, Clear carries it.
Bye.
Jasen
K
krw
Dumb KRW.
How original. Considering the source...
Absolutely fine.
As is the rest.
Even the part about "dumb donkey".
Dumber-than-dirt donkey, the context from above was a WEB SERVER.
Why bother quoting if you can't read them?
The issue at hand was WEB SERVERS. You stepped in your own dirt,
dumb donkey.
You're incapable of reading, even when when I lay it out in front
of your stupid stubborn donkey nose.
Now grow up !
Now learn to read.
