Opto-couplers in smps - part 3 (final chapter)
K
krw
Nerr, nerr, nerr. I said that first.
I'll take that as an admission that you're an illiterate dumb
donkey. Moved goal posts noted.
Eeyore
krw said:
[email protected] says...
I take that as an admission you need to lighten up.
Not playing any more now. :p
Graham
K
krw
Why should I lighten up. It's fun whacking dumb donkeys. It makes
'em look even dumber when they squirm.
You will. You can't resist making an ass out of yourself.
Terry Given
Steve said:
Terry,
I've uploaded an improved schematic.
All components are now given a value, including "primary" side opto
circuit and 2525 internal error amp, though is used only as a buffer.
Best regards
Stefan
OK.
Firstly, I wonder what the effect of measuring the voltage across both
outputs is. I look at that and think that Ltotal = 160uH and Ctotal =
10mF. So a quick energy balance:
I+ = I- = I (balanced load)
E_L1 = 0.5*80uH*I^2
E_L2 = 0.5*80uH*I^2
E_L = 0.5*160uH*I^2. OK, the L's sum.
likewise for the caps:
E_C1 = 0.5*20mF*(V/2)^2,
E_C2 = 0.5*20mF*(V/2)^2,
E_c = 20mF*(V/2)^2 = 0.5*10mF*V^2
so a re-drawn circuit is:
---] xfmr [---[160uH]--[ESR_L]--+---- +100V
40T 40T |
[10mF]
[ESR_C]
0V
DC gain = (Vin/Vramp)*(Ns/Np) = (320/2.6)*(40/40) = 123
note: if you regulated only one output, then you would reflect the other
LC circuit (easy, same no. of turns) to the regulated output, and
calculate the parallel equivalent, giving 40uH + 40mF, and the DC gain
would be 61.5
Note that the effective inductor ESR is the sum of the two; for the
caps, it turns out to be that of a single 10mF cap, as each 20mF cap is
2 in parallel (ESR_20mF = 0.5*ESR_10mF) so the sum is ESR_10mF
You can usually ignore the choke ESR. Because it has the full output
current flowing thru it, the choke is (usually, not always) designed for
extremely low losses (hence low ESR). if its not quite negligible, the
next approximation is to add it to the cap ESR. Or you can just use the
actual transfer function:
The AC transfer function of the power stage is:
Vout(s)/Vc(s) = Xc(s)/[Xc(s) + Xl(s)]
Xc(s) = ESR_C = 1/(s*C)
Xl(s) = ESR_L + s*L
(s = j*w)
the zener resistor current is 11mA c.f. a shunt circuit maximum of
Ishunt_max = (12 - 1.2 - 2.5)/2k2 = 8.3mA
this is a lot higher than your 5mA figure. I guesstimated Vled = 1.2V.
The TL431 cant pull lower than 2.5V.
regardless, 8.3mA < 11mA, so the zener will clamp the opto supply at ~
12V, and it wont vary by much.
the LED will see a maximum of 8.3mA - 1.2mA (the 1k resistor) = 7.1mA.
OK, we've established the zener shunt regulator works.
The TL431 circuit transfer function (from Vout to Vk) is:
Vk(s)/Vout(s) = -Zf(s)/Zin(s)
// = parallel
Zf(s) = [1/(s*220pF)]//(47k + 1/(s*22nF))
Zin(s) = 47k + 47k//[1/(s*22nF)]
the transfer function from Vk to Iled is simply -1/2k2
so Iled(s)/Vout(s) = (1/2k2)*Zf(s)/Zin(s)
the transfer function from the opto transistor to led is:
Ibjt(s)/Iled(s) = CTR*1/(1+s/w_opto)
where w_opto is the corner frequency of the opto itself. You probably
cant ignore this.
and to get from the opto bjt to the control voltage, the transfer
function is Acl(s)*(-8k2)
its -8k2 because the voltage is (5V - 8k2*Ibjt), and the 5V (being
constant) disappears when you take partial derivatives.
where Acl(s) is the error amplifier closed-loop gain. for a shitty old
smps controller, these error amplifiers can have quite low GBW. look it
up in the datasheet, but I suspect you can ignore it as the gain is one.
Acl(s) = 1/(1+s/(2*pi*GBW))
OK, I looked it up, its 1MHz so you can safely ignore the controller
error amp, and set
Acl(s) = 1.
Putting it all together, you get:
Vc(s)/Vout(s) = 1*(-8k2)*CTR*[1/(1+s/w_opto)]*(1/2k2)*Zf(s)/Zin(s)
simplifying:
Vc(s)/Vout(s) = -3.73*CTR*[1/(1+s/w_opto)]*Zf(s)/Zin(s)
and thats all you need to close your loop.
I might have made an algebraic error or 6, but the technique is pretty
much there. If I was being paid, I'd be very careful to get it right :)
Cheers
Terry
Andrew Edge
Terry,
Best regards
Stefan
Where did you upload that ... I still see the old circuit .
Andy
Steve
Best regards
Stefan
OK.
E_L1 = 0.5*80uH*I^2
E_L2 = 0.5*80uH*I^2
40T 40T |
[10mF]
[ESR_C]
0V
would be 61.5
Xl(s) = ESR_L + s*L
(s = j*w)
// = parallel
cant ignore this.
error amp, and set
Acl(s) = 1.
simplifying:
Cheers
Terry- Dölj citerad text -
- Visa citerad text -
Thanks Terry,
I'll go through your calculations and try to understand.
Again, thanks
Stefan
