oscilloscope calibration
Mike
Hi there,
Does anybody know of a place somewhere in southern NJ (or closeby area) that
calibrates oscilloscopes? How much does this usually cost? I tried searching
for some places but the closest place is in philly, pa.
Thanks.
Bob Masta
Hi there,
Thanks.
I assume you are talking about the voltage and frequency
ranges. If so, you can probably make your own calibrator.
Many scopes have a simple calibrator built in, just a square
wave at 1 volt and 1 kHz or some such. You can use a
crystal and some frequency dividers to get a whole
range of frequencies. Use them to chop the output of a
precision voltage reference. You can also make a
precision divider by matching a series of resistors, or you
can use digital PWM to produce a high-frequency pulse
train with a duty cycle that you can set in steps.
Not only is this a good project, it's a handy thing to have
around the lab.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Mike
Hi Bob,
That definitely does sound like a good project. If I could do it myself, I'd
rather not pay someone else. One of the sellers I came across says that the
frequency of the calibration is 975mhz, and the book actually calls it a
1khz signal. Is that true? Is it bad if the person modifies the internal
circuitry to reflect closer to 1khz?
I have zero experience with scopes... please excuse the ignorance.
Thanks.
Mike
I'm pretty familiar with voltage dividers, series, and parallel circuits, so
I'm sure it's something I can handle. Also, I came across a seller on ebay
that retrofitted the scopes crystal to
CFoley1064
Subject: oscilloscope calibration
Date: 12/12/2004 8:11 PM Central Standard Time
Message-id: <[email protected]>
Hi there,
Thanks.
Hi, Mike. You might want to call the local junior college or trade school and
ask them where they go for calibration services.
Good luck
Chris
Peter Bennett
Hi Bob,
Thanks.
Mike
I don't think the built-in scope calibrators should be relied on too
much for frequency. Their primary purpose is to provide a nice square
wave that you can use when setting the probe compensation on a 10X
probe.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Bob Masta
Hi Bob,
I'm not sure what device the 975 Hz (probably not milliHertz) refers
to. I don't advise messing with the internal circuitry of the scope,
but of course if you build your own it will be as accurate as the
reference crystal you use. Since scopes are usually just for visual
comparisons (unless you have one of those fancy ones with
counter circuitry built in), you only need to make is as good as you
can resolve on the scope face. The raw accuracy of any crystal
you find will probably be much better than that.
Best regards,
Bob Masta
D A Q A R T A
www.daqarta.com
Mike
Yes, I meant 975hz -- doh.
Thanks for the input. I wouldn't think of modifying any of the scope
circuitry; I was just baffled by someone else doing it.
Cheers,
Mike
