Oscilloscope primer rec?
Eric R Snow
Today I used an oscilloscope properly for the first time. It is a
Tektronix 465B. The manual for this 'scope isn't that helpful when you
aren't familiar with the terms of the 'scope or what it measures. So,
I would like, please, to get a recommendation(s) for a book aimed at
beginners like myself.
Thank You,
Eric R Snow,
E T Precision Machine
Chris
Thank You,
Eric R Snow,
Hi, Eric. Congratulations. The 465B is a great scope. It's easy to
use, easy to repair, and it's a great one to learn on.
By far the best online resource for learning about scopes is from
Tektronix, called "The XYZs of Oscilloscopes". It's available in .pdf
format from Tektronix:
http://www.tek.com/Measurement/cgi-...rement/App_Notes/XYZs/&FrameSet=oscilloscopes
http://tinyurl.com/9m267
Once you've got that intro, the manual will make a lot more sense.
Good luck
Chris
W
w2aew
Thank You,
Eric R Snow,
Ditto on the response recommending the Tek note (XYZ's...)
Also, check out a few of these links (found with google):
http://www.ee.usyd.edu.au/tutorials_online/topics/labintro/cro.html
http://web.telia.com/~u85920178/scope/osc-0.htm
http://www.williamson-labs.com/scope-main.htm
http://en.wikipedia.org/wiki/Oscilloscope
....etc.
tekamn
Well, and because the OP mentioned he already has the manual: The
section "operation" has a couple of good measurement examples.
hth,
Andreas
