Panasonic inverter microwave controller as timer
K
Ken Wright
I am trying to use the controller board from a Panasonic
inverter microwave as a timer but am having no luck
getting the relay output to work properly.
The controller board has a 3 wire connector going to the
inverter board. I have been able to determine that one
pin outputs 1 Htz pulses (appears it would interface to
5v logic). Another pin appears to be an input but I can't
figure out what it wants. With nothing connected to any
of the three pins the relay shuts off after 3 seconds
regardless of the initial time requested. If I jumper
the input pin to the center (common?) pin of the connector
it will run for 23 seconds before it aborts. Jumper
directly from output to input aborts after 3 seconds.
As a simple count down timer with no relay it functions
normally. Clearly the inverter board is supposed to send
some kind of 'OK' signal to the controller board as a fail
safe mechanism. I have not found a schematic online.
Has anyone gotten one of these controllers to work as a
power timer?
thanks,
kw
JIMMIE
power timer?
thanks,
kw
----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==----http://www.pronews.comThe #1 Newsgroup Service in the World! >100,000 Newsgroups
---= - Total Privacy via Encryption =---
The timer is looking for some saftey logic from the power supply I
havent really looked at it but I can get you a schematic. Email me.
