Panel mount connectors - screw sizes.
NeilTheDruid
Jun 21, 2011
6
Hello everyone,
I am just finishing up modifying my old Atari 7800, I've put an s-video circuit in it and I am very pleased with the outcome. Last thing to do is mount the s-video socket to the chassis, I've basically done everything I need to, drilled holes etc. Now I just need to screw it down. This is the datasheet for the connector I'm using, as you can see, the holes are pretty small maybe about 1/16 of an inch in diameter. Could anyone recommend a screw size?
Cheers :)
Resqueline
Jul 31, 2009
2,848
M2 will go clear through the hole, and M3 will enter (or make) threads in the plastic, or so it seems. (A common chassis screw dimension is 1/8" = 3.2mm btw..)
