Paralell resistors
ImperialGuardWH40K
Nov 17, 2005
12
    I recently found out that if you have resistors of the same value wired in paralell, the resistance is lower than one of the resistors in the paralell. For example, if you have 2 resistors that are 50 ohms each, wire them in paralell and their resistance is 25 ohms each. I don't understand how having resistors in paralell will lower resistance. Can someone tell me why the resistance divides by 2 when you add 2 resistors of the same value?
Thanks a ton.
ante1
Jan 24, 2004
4,136
E-Lab has this link for you: http://www.electronics-lab.com/articles/files/dc_circuits_lecture.pdf
Paralleled resistors on page 5.
indulis
Nov 21, 2005
488
Any number of resistors of the same value in parallel is equal to the resistor value divided by the number of resistors, it's not just limited too 2... i.e. 10, 100ohm resisistors in parallel is 100/10=10ohms... it's one of those things that works out that way given certain conditions.
The equation for any values in parallel is Rval= 1/ (1/R1+1/R2...1/Rn). I suppose you could algebraically manipulate the equation to get Rval=R1/n when R1=R2=R3... if you wanted to really prove it to yourself.
priya_6925
Jul 21, 2006
COZ 2 FIND TOTAL RESISTNCE WHEN NO OF RESISTORS R CONNECTED IN PARALLEL THERES A FORMULA ; 1/R = 1/R1 +1/R2 + . . . +1/RN
N
nanop
a helpful formula to know when u are only finding the resistence of only 2 resistors in parallel is
Rt= (R1*R2)/(R1+R2)
Cabwood
May 31, 2006
86
I believe you are confused because you stated that two 50 Ohm resistors in parallel causes them to become 25 Ohms each. This is incorrect. They stay 50 Ohms each, but the resistance of the whole becomes 25 Ohms.
A single water pipe has a certain resistance to flow, but two such pipes permit twice as much flow. The same principle applies with electrical resistance. Two identical parallel paths provide half the total resistance that one would provide.
Bugger. Sorry Zeppelin.
Cabwood
May 31, 2006
86
No. I said sorry because I had just realised I repeated exactly what you said.
ImperialGuardWH40K
Nov 17, 2005
12
yeah, I was refering to how does it work physically, but its nice to know the math. Thanks a ton everyone, I get it now ;D.
N
nanop
Can't believe something in basic electronics got so much attention, confusion.  :)
prateeksikka
Jun 19, 2004
736
an alternate path for the current to flow.
more the number of paths ,more free is the flow and hence lesser resistance!
