Parts for a Vacuum Tube amp
clRedwolf
I have a question (don't we all?). I am building (or at least trying to
get the parts to build) a 'DC Darling' tube amplifier:
http://www.geocities.com/bobdanielak/darling.html
I'm buying the parts I can from Mouser. So far, I have all the stock #s
written down except the parts I can't find. I need help with these parts.
First of all, I have only made 3 changes to the schematic, all minor. The
biggest one was to change it to where the wire between VT2 and VT12 doesn't
also connect to the left audio transformer (that appeared to be a mistake).
The others are of no concern (changed Rg1 & 11 to a phenowhatsit (variable
resister) as a volume knob, and used a DPST power switch.
Okay, now for the part I need help with. First off, realize this is my
first time working with AC circuts, but I feel that I can do so safely now
(if all else fails, I use chopsticks to work with it ;) ). Here's the
parts that I can't seem to find:
R2 (1R 5W) - What does the R stand for, as none of the resisters at Mouser
are rated by that? Or is that a typo for K?
T1 and T11 - Okay, I know squat about audio transformers. But even then...
The schematic calls for a 4.8K Primary 15W transformer. I'm going to take
a wild guess and say that 15W is the for the output, but what the heck is
the 4.8K primary for? Is that the impedence of the primary? Where would I
get such a transformer?
L1-A 5H 75mA Inductor. Mouser doesn't sell them over 2 H it seems. I'll
look at other places...
C1a and b - 47 uF 500V capacitors. I just need to go somewhere besides
Mouser. Know any other *decently priced* electronics vendors? decently
priced=cheaper than, ugh, Radio Shack.
Thanks in advance. Oh yeah, and Hi!
Michael A. Terrell
http://www.google.com/search?hl=en&ie=ISO-8859-1&q=Hammond+transformer&btnG=Google+Search
cornytheclown
google search for "hammond manufacturing" and "antique electronic
supply" or go here and ask your questions in the antique radio
newsgroup....
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&group=rec.antiques.radio+phono
also.....this is the best bet for old radio parts.....
http://www.oldradioparts.com/pg2.htm
this guy has it all for old radios....I hate giving up this source but
I am kind person. scroll thru his transformer list.... 30.00 min
order....he wont answer questions or give advice....you must be
succinct and business like when dealing with him....he is the "soup
nazi" of old radio parts but he is the best in my opinion.
ebay carries a lot of tube stuff...just use the search engine or look
for the tube radio parts section but searching will be your best bet.
crooksie
why not email bob himself for the info ?
Rich Grise
1 ohm 5 watts. I guess thats to reduce surge, but it isnt really
necessary. Few commercial amps have such refinements. This is not a
refined amp. ....
Regards, NT
Actually, I'd say it's rather important - surge protection, yes,
but even after the heaters are warm, it still participates
in the voltage divider.
Cheers!
Rich
N
N. Thornton
But there is no need for any such 'surge protection'. Few commercial
amps use a 1R to reduce the heater surge a bit, as there is no reason
to. These just aren't particularly well designed amps. They lack a
fairly essential safety feature, and include assorted sillies.
I couldnt see any voltage divider on the cct diag which the 1R is a
part of, nor can I come up with any need for one. Perhaps you could
explain.
To the OP, I would pick the 2nd circuit, labelled 'latest one' rather
than the dc one. The dc offers no real advantages, and will just
consume more power and generate more heat. It is also very vulnerable
to dc on the input, to which it would probably react with a meltdown
or a fire.
I built basic valve amps like these some while ago, and was surprised
at how good the results were, but these days people seem to get weird
over the designs, and specify 2H chokes when theres no reason for a
choke at all, and so on.
I would also use pentodes rather than triodes myself, and I'd use one
valve per channel rather than 2 or 4. But the design should work OK
with triodes.
Regards, NT
PS always discharge the HT caps before touching anything.
Rich Grise
[email protected] (N. Thornton) wrote in message
It could be argued that it protects the cold filaments from a high
inrush current, which could shorten the tubes' lives. Maybe "inrush"
would be a better choice of word than "surge." :)
explain.
Happy to! The only 1R I'm aware of was the one in the DC filament
supply. The voltage divider is the 1R in series with the filament
array, which is the other resistor of the divider. Tube filaments,
especially power tubes, consume significant power. About the only
reason I can think of to do it that way would be either that they're
able to use a conveniently-available transformer for odd-ball
filament voltages, or it could be to scale down line variations.
or a fire.
I didn't delve into it that deep, so really can't give an opinion on
that item. :)
with triodes.
Regards, NT
Cheers!
Rich
N
N. Thornton
It could be argued, yes, but its been found to make no significant
difference to filament life, thats why it isnt done. If tube life
could be even a little extended this way we'd have seen heater Rs in
some high end commercial amps.
filament voltages,
yeah, I dont know the heater V rating on those tubes. Logically I'd
simply pick the right transformer for the job. I would think the odds
are the valves'll be 6.3v anyway, but you never know.
I think it would actually worsen things in this respect. Valve heaters
are to some extent self compensating, as temp goes up R also goes up.
The 1R OTOH has no such stabilising effect, and thus reduces the
amount of stabillisation of heater power.
Now if the amp were using a series capacitor straight on the mains to
provide heater power, then yes I'd be all for the series R, and it
would extend tube life. But the way its set up, I think in truth its
functionless.
Also I'd be in favour of a small R in the HT line, so that if the amp
is wired wrong the R pops instead of the valve heater - but thats
absent. I think really they're just not very good designs. Should run
OK tho.
Regards, NT
clRedwolf
Thanks all! This should really help. In response to using junk parts,
there's one problem with that...I don't have much in the way of that.
About 6 months ago I did, but since I never found a use for them...I took
out some 'stress releif'. I know it was bad...but it was fun!
Anyway, I should start soon. I just need some money to burn on
this...which I *should* get later this week (or month, knowing my luck).
