Passing a pulse around a 7400
liderbug
Feb 16, 2015
My greenhouse. Raspberry Pi and a DHT22 (temp/humd). Right now I connected directly https://learn.adafruit.com/dht-humidity-sensing-on-raspberry-pi-with-gdocs-logging/wiring
I'd like to add a second DHT22 for outside temp/humd. (and other I/O) First RasPi does NOT interface TTL. The interface is 3.2v. I simulated using a 74LVX00 and an input from the GPIO as an A/B switch. Then I found out (cart...horse...) that to read data from the DTH22 I (the SW) sends a Vcc-0-Vcc pulse and duck here comes the data stream. And by inserting a 7400 in-line - OhWoops ain't got no pulse?
Suggestions?
Thanks.
cal
Most are going to find your shorthand description useless.
You will have to describe what you have and what you want clearly with a drawing also.
The article you linked describes how to connect 1 or more DHT22s to the Raspberry Pi. Why are you not doing what it suggests?
