PC Based Oscilliscopes
Jim Douglas
Anyone use these? Any recommendations good or bad? I am looking at some that
have Scope, Meter, Spectrum Analysis, etc. Are the "multi-use" type PC
scopes any good? I see some that are down around $200-300? which is in my
price range.
Thanks!
Jim Douglas
www.genesis-software.com
Carrollton, TX USA 75006
Latitude 32.9616
Longitude 96.8916
Teddy Rubberford
that
price range.
Thanks!
Jim Douglas
Latitude 32.9616
Longitude 96.8916
is this a job for the goatse man ?
http://goat.cx
Depending on what you are trying to measure,
they can be a very usefull tool. A "real" scope is
much better, but much more expensive. IF you
can, try before you buy. At the very least get to
do a hands on demo. I use several different
audio applications for a variety of my measurement
needs. For the serious stuff, I borrow a good scope
from work.
The biggest "flaw" is they average the readings,
so if what you are looking for is a rarely occuring
gltich, a most PC scoes will miss it. For looking
at normal waveforms they do a respectable job.
Terry
m II
price range.
This one is free. It's only 20khz, though.
http://polly.phys.msu.su/~zeld/oscill.html
100Mhz. Price?
http://www.tiepie.nl/pages/uk/hscope3.html
Scope and logic analyzer..
http://www.bitscope.com/?c=7E39669B86BB499ADFA6091527355655
mike
Dr. Anton T. Squeegee
price range.
My gut reaction when I see a PC-based O-scope is to cringe.
I would stay away from them. For the same price range that you
mention, you could get one heck of a nice Tektronix 7000 series 'scope,
or perhaps a 400 or 2400 series portable, all from the used/surplus
arena (more specifically, from ham radio swap meets or Greed-Bay).
Example: The Tek 7603 was one of their most popular, and is also
one of the most plentiful on the surplus market. It has a mainframe
bandwidth of at least 100MHz, and can often be found for around $50-$100
with plug-ins.
If you want some serious bandwidth, you should have a look at the
Tek 7904 or 7104. The base frames have bandwidths of 500MHz and 1GHz,
respectively, and you should be able to get a good 7904 with plug-ins
for a little over $300.
Your test equipment needs are, of course, your choice. However, I
would like to say that just because a test instrument CAN be designed to
work in a PC environment does NOT always mean that it SHOULD be. Good-
quality input stages are hard to do (there's a reason Tek put so much
R&D into theirs), and they are one of the main driving factors where
cost is concerned.
I have little faith that the Taiwan-import PC-based (alleged) O-
scopes can do a proper job in this regard. Good quality test gear is an
investment, and it should be treated that way.
Keep the peace(es).
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
m II
There's one major advantage to the PC based scopes. It's STORAGE of
waveform. When I was younger we had to put a hood over the front of the
scope and use a Polaroid to get shots of easy to miss signals.
A real storage oscilloscope costs a fortune, but if you can get a PC variety
that fills your frequency needs, I'd go for it. Three or four hundred bucks
is a bargain when accompanied by a good warranty..
mike
Rich Webb
http://goat.cx
Ahh, apparently some 12-yr old has just been introduced to goatse
(and/or slashdot) and wants to spread the pleasure.
No pun intended.
Seen Tub Girl yet?
Brian Hill
mike
Good post you Canuck!! Your all right tech wise :)
73 and good DXing.
Brian
A lot of radios and 100' of rusty wire!
Zumbrota, Southern MN
Brian's Radio Universe
http://webpages.charter.net/brianhill/
EMAIL- brianehill@$100charter.net
(Hide the $100 to reply!)
Rich Webb
price range.
Some of them aren't too bad, although in the $200-300 range you'll not
get any record setters. For one data point, though, some of the higher
end scopes do use Windows as their user interface. Check out Tek's
TDS6000B at http://www.tek.com/site/ps/0,,55-14873-INTRO_EN,00.html
For one possiblity closer to your price range, take a look at
http://www.linkinstruments.com/oscilloscope.htm. I have not used their
o-scopes but I have (and use) one of their PC-based logic analyzers.
Been reasonably happy with it.
m II
I love damnation by faint praise. It's a good thing you haven't heard me
trying to practice this bass. You'd retract that
EADG EADG I mean. sheesh..how hard can it be? I'm starting to suspect
they shipped the wrong instructions with it, not that it matters, I can't
speak Chinese anyway.
http://www.clicmusic.be/images/hands_crossed_jpeg.jpg
mike eadg eadg
price range.
Thanks!
Jim Douglas
Latitude 32.9616
Longitude 96.8916
They are too limited to be worth the money.
Get a used Tek in good working order in that
price range, as another poster mentioned.
Ed
Tektronix DSA602A Digital Signal Analyzer. All kinds of waveform
storage and analysis, and a floppy drive as well. Runs about $400-$500
on the used market, uses 11-series plug-ins, mainframe bandwidth of
1GHz.
And how long will it last? If it's made up entirely of custom
parts, and cannot be repaired by the end user (at least at the module
level), then I would hardly think of it as a good investment.
When I buy test equipment, I expect it to be serviceable for a
MINIMUM of ten years. Very few items that I've bought new have measured
up to that requirement.
m II
1GHz.
You make some valid points, but I still have concerns. Tektronix, among many
others, has been known to use proprietary chips/components in their scopes.
These may be getting hard to get. That would tend to even out the decision
making process, all other things being equal.
Having said that, Tektronix stuff is very nice, quality made merchandise.
I'm admiring a 7B92A dual time base module even as we speak. I just don't
want to wind up like Hamlet...
Alas, poor 7904, I knew it Horatio...
mike
I'd rather have a stand alone scope myself. I don't know how good a
scope you need, but you can find them real cheap if you look around.
IE: hamfests, etc..I have 3 scopes, but the one I use mostly now is a
Kikusui COS 5060. I bought it for $50...It's a 60 mhz scope..It's
no top line scope, but it's quite usable for most of my needs.
I also have an old heathkit scope, which still works, and also an
ancient 60's tube hickock, which was built by tektronics...Has the
plug in tektronics preamps, etc...
But the old tek scope blew a gasket the last time I plugged it in.
I consider it tit's up...The kikusui is pretty modern compared to the
other two... MK
Dale H. Cook
A "real" scope is
??? He said his budget is $200 - $300, and he can buy a older Tek or
HP 100 MHz dual trace 'scope for that kind of money.
Dale H. Cook, Chief Engineer, WWWR Roanoke VA, WCQV Moneta VA, WKBA
WZZI Vinton VA, WKPA WLNI WZZU Lynchburg VA, WMNA/WMNA-FM Gretna VA,
WOWZ Appomattox VA
http://members.cox.net/dalehcook/starcity.shtml
Dale H. Cook
Same here, but I carry very little that I've bought new. Most of what
I have bought new, and use on a regular basis, was bought 10 - 20
years ago. The newer items that I carry are mainly ones that did not
exist, or that I did not need, 10 - 20 years ago, such as my CAT5
tester.
The instruments that I use for work have to be rugged and reliable, as
they live in my Explorer and frequently travel up rough mountain roads
to transmitter sites. My road 'scope is a 30+ year old Tek 453,
although the probes are fairly recent. I have, however, replaced my HP
audio generator and distortion analyzer, both only slightly newer than
the Tek, with my laptop equipped with a USB audio card and audio
generation/analysis software.
WOWZ Appomattox VA
Jim Douglas
Thanks for all the input, I am going to pass on the PC stuff and shop EBay
and ?? for a good used scope. Any recommendations other than EBay?
Bob Masta
price range.
My personal preference is a conventional benchtop
scope for high frequencies, and a sound-card-based
PC scope for audio work. I use my own Daqarta
shareware for the PC scope (shameless plug). It
only runs in real-mode DOS on old ISA-bus systems
with Sound Blaster cards (or lab-type boards, which
are pricey). I run an old cast-off 16 MHz 386 system
that works just fine for this purpose.
The PC gives me real-time spectral analysis, which
is great for distortion measurement and especially
for distortion adjustments. Another big advantage is
that the PC can generate complex test signals and
keep them exactly in sync with the input signal
that is responding to those signals, so you can
use signal averaging to measure noise *way*
below the noise floor.
Windows-based version is under construction,
but won't be released for several months yet.
Hope this helps!
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
craigm
Try looking for used equipment from leasing companies.
Also look for plant closings that may result in equipment sales or auctions.
craigm
