John said:
I read in sci.electronics.design that "Aubrey McIntosh, Ph.D."
Rhubarb, rhubarb?
A cleaning material for wooden decks contains mostly oxalic acid. I
have forgotten the brand name. When I read the price and the ingredient
list on the label, I thought a while, bought a stiff brush and a gallon
of vinegar, and the change in my deck was just short of miraculous.
I don't know the term 'greensalt synthesis'. Google doesn't help much.
No, I couldn't find it either. A few years ago there were dozens of lab
write-ups with the name, but it is archaic.
The formal name is potassium tris (oxalato) iron (III) trihydrate or
alternately potassium iron(III) tris-oxalate hydrate. It forms large
clear emerald green colored crystals. The color change is when the
solutions are mixed is immediate and dramatic, so it makes a nice
freshman chemistry lab. The toxicities and mess are low.
My memory was bad, it should be iron(III) and not iron(II) to be
soluble, so it should be easy.
There is a nice picture of the structure of the compound in this lab manual:
http://www.hmpublishing.com/hmplabscollection/Tatz123/Tatz123-137-144.pdf
A fairly short description of a synthesis, using Fe(Cl)3 is given at
http://www.wpi.edu/Academics/Depts/Chemistry/Courses/General/feoxalate.html
My thinking is that the oxalate's oxygen will grab the iron away from
the rust's oxygen, given good conditions. Also, the color change gives
immediate status on success.
Oxalic acid just forms colourless, soluble ferrous oxalate, I think.
Doesn't EDTA form complexes with Fe?
A compound with a central metal atom and other moieties around it that
have "lone pair electrons" is a "transition metal complex," so they both
the oxalates and the EDTA are correctly called "complexes" or
alternately "chelates." The oxalate is a "chelating agent" or a "ligand."
The key to having them be soluable is to have the complex carry a net
charge. So, if I made oxalates using Ni, Cr, Fe, Co, and try to walk
across the
periodic table, I do end up with some beautiful colors, but
some are solutions and some are gunk.
