(Perhaps this subject should be moved to the CAD forum where it belongs?)
I just tried out the pad 2 pad program. Here are my comments regarding it:
This is another company like ExpressPCB which gives you software so that they can make your boards. There is no feature to make a gerber file, so you will never have another board house make the boards. However, they do give you the capability to import a net list from another board layout program. No export.
Even though the software allows you to print, the top layer is in red and the bottom layer is green. These colors will not give you a dark enough image to make a transfer for making your own boards. My printer has the feature to print colors as black and white. When clicking on this, the print still comes out as a gray image since this feature only changes color to grayscale. It is still not black enough to make a transfer image to make your own boards.
Now, there IS a trick that will work. When you are done with the board, you can go into "Layers" and change the colors of the top and bottom art to black. Since the screen background is black and not changeable, you will no longer see your work, but it WILL print black. ( I will bet pad 2 pad never thought anyone would do this ;D )
Over the years, I have added many different layout programs to my CAD group. Some are so simple, you lay out pads. Others must have many engineering parameters input before you can begin. Then there are several stages between these two extremes. I have found that the easier the program, the less features you will have to benefit the design. This is not always a bad thing. Sometimes, you only need to layout some pads fast and proto a quick idea.
I did not find a schematic section to this program, so if it does have one, I cannot comment on it. The library is pretty limited, but you do have the choice of choosing from many different sized round pads and stamping them down individually if needed.
Until I got around the print problem, I had pegged this program as useless. But like I mentioned above, you can get around it.
Too bad it does not have schematic and auto route features.
MP
