Peavey XR886 Amp no output from Mic inputs
lenc
Aug 15, 2017
I hope this is the right place to post this. I replaced the Dual Quad RCA connector for the Tape Input and output on My Peavey XR886 PA amplifier when I closed the amp back up no sound from mic inputs. If anyone knows of any common probabilities for my problem please reply.
14,485
hi there
welcome to EP :)
well since you have opened it up, the highest probability is that you have dislodged a connector/patch lead between circuit boards or similar
This assumes that it was working OK before you opened it ?
So open it up again and check EVERY connection/cable and see if you can find one that has either partly or fully fallen out
