Why amp is not stable while charging a 3s battery
Usamaj
Jul 14, 2022
13
I am charging a 3s bettery but the amp is not stable what is the possible reason for this
Alec_t
Jul 7, 2015
3,821
You may be overloading the supply. Post links to the amp and its supply.
Post a schematic of your amp and we might have a clue.
bertus
3,874
Is the amplifier working correct when not charging?
Then there could be a problem with the charger.
Bertus
crutschow
May 7, 2021
991
I probably can think of a dozen or so reason but those would all be WAG's.
So what are you using to charge the battery?
14,310
I updated the thread title.
"s" stands for series connected. "3s" is 3 cells in series.
In contrast to "p" for parallel connection.
Also combinations of "s" and "p" are possible for example 2p3s means 3 packs in series, each pack consisting of 2 cells in parallel.
