Phase voltage in AC Delta connection
jacklam2048
Feb 22, 2021
33
Hi, my customer asked us to develop a three phase AC deepfryer, the input voltage is 230/380V Main voltage, Power 7000W. My colleague created a drawing in Wye connection as shown.
I try to create the same but in Delta connection, but I am unable to figure out the phase voltage (i.e. the voltage across each heating element). Can anyone help or give me some clues ?
Thanks a lot !
Martaine2005
May 12, 2015
5,315
This site also has all the calculations.. Here.
It's way over my head but the information is there.
Martin
If your elements are the original star connected, you'll blow the guts out of them on delta.
Reason being the original star has 2 elements per phase with any imbalance on the neutral.
Delta has one element across across the two phases.
Why you would need to change to delta is beyond me.o_O
jacklam2048
Feb 22, 2021
33
Hi Bluejets, Thanks your reply.
I think in Delta connection, the current across each heating element is much smaller comparing to the phase current in Star, thus the heating element connections are not so easy to burn out. Sometimes the burn out of the terminals at the heating elements is a headache and cause a lot of maintenance cost.
14,306
Only if the impedance of the heating element is increased accordingly.
As the voltage increases by sqrt(3), impedance needs to be tripled to maintain the same power:
Star: Pstar = Vstar² / Rstar
Delta: PDelta= VDelta² / RDelta = (Vstar × sqrt(3))² / RDelta = 3 × Vstar² / Rdelta
With the requirement Pstar = Pdelta you get
PDelta= 3 × Vstar² / Rdelta = Vstar²/ Rstar
Cancelling Vstar out of the equation gives:
3 / Rdelta = 1 / Rstar or equivalently: Rdelta = 3 × Rstar
Tha fios agaibh
Aug 11, 2014
2,253
I think the confusion is between supply and load.
The phase current inside the windings of a Delta connected transformer will draw less current than a Wye.
But, you are showing your deepfryer load wired with a Delta configuration.
If you apply 230v 3p to the Delta load, you are changing the impedance with the extra windings.
Rough math shows your amperage increasing from 10 to 15 amps per leg and wattage increasing from 2.34kw to 3.45kw per element.
I agree with Bluejets that you'd blow it up if hooked up this way.
jacklam2048
Feb 22, 2021
33
jacklam2048
Feb 22, 2021
33
Yes, I have calculated:
In Wye connection, the resistance of each heating element is 22.6 Ohm.
If I convert it to Delta connection, the resistance of each heating element has to be 68.48 Ohm.
Thanks all people's reply !
You are helpful !
jacklam2048
Feb 22, 2021
33
Thanks Harald, Your calculation is a great help !
