PIC programming
Baxter Burgundy
Nov 18, 2014
38
I'm planning on using a PIC16F8X as a simple frequency counter outputting onto a 3 digit seven segment display. I've tried reading some tutorials on PIC programming but I just can't get my head around it. I suspect it would be a very simple programme once I understand the programming language. Can anybody help?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
I think the best way to learn new things is by doing. Start with a simpler application - flashing an LED is the usual "Hello, World!" program for microcontrollers. Once you get that going, you will have a much clearer understanding, and you'll be ready to move on to something more complicated. Perhaps not a frequency counter, but you'll get there eventually.
I would not recommend using PIC16F84 or PIC16F88. These are obsolete chips that are more expensive than newer, more powerful chips.
For example, the 16F1847 has twice the program memory, 3 times the RAM, runs at 4 times the speed from the internal oscillator, has more peripherals and costs less than the 16F88. And they are pin compatible 18 pin chips.
Colin Mitchell
Aug 31, 2014
1,416
"I'm planning on using a PIC16F8X as a simple frequency counter"
It has already been 2 weeeeeeks for a reply from you.
This is going to take you 4.56 years to get a programming working, at this rate.
