Pic Programming
Status
Not open for further replies.
Kath
Oct 3, 2015
3
Can you help me create a program on a PIC16F877A microcontroller using C language with this kind of problem?
Design a control system that will display a counter up to 9.
When add button is pressed, it will add 1 and will display to its seven segment display.
When start button is pressed, the sequence will be flash the led for 500ms depends on the number of count display.
When interrupt button is pressed, it will paused the program and when it pressed again, it will continue the program.
I really need your help..
14,317
What have you done so far to tackle the task?
What does your circuit look like (how are the buttons, the LED and the 7 segment display attached to the PIC)?
Does that mean that the LED flashes count times with an on duration of 500ms?
14,487
Aw, guys! Clearly this gal is in over her head and doesn't have a clue where to start.
yup agreed ... those of you that do know about pic programming, please give some good guidance
I think you should do your own homework
Nicholas, that was a pretty harsh comment
we all have to learn these things sometime and a little helping nudges in the right direction can do wonders
cheers
Status
