PIC16F877, 250Hz PWM
aymensmurf
Mar 14, 2016
28
I need 250Hz PWM out of a 20MHz clock.
I'm using PIC16F877.
any help ?
Arouse1973
Adam
Dec 18, 2013
5,178
Firstly welcome to EP. Secondly, it's quite a good idea to give as much information as possible of your requirements. Unfortunately you haven't. Questions I would like answered are :
1) What language are you programing in?
2) What is the % of duty cycle you require?
3) How far have you got already yourself?
And out of interest what's the project, anything interesting?
Adam
aymensmurf
Mar 14, 2016
28
->C
->50%
->so far, I'm doing everything using the delay function.
->I'm trying to command the speed of a subway, using three Pulses, every pulse command a Thyristor.
The thing is, the pulses have to be "=1 in 50us and =0 in 150us" in a 4ms periode.
(srry, my english is kinda bad)
Minder
Apr 24, 2015
3,561
Then you may have to use a low freq clock in such as external osc or crystal input, I have used the 32khz watch crystals for some low freq apps to run TMR1.
I would think the 16F877 has this feature.
M.
aymensmurf
Mar 14, 2016
28
#M.
I think i have to use a 4Mhz external osc to get 250Hz PWM.
and that won't help, coz the program will go slow.
Minder
Apr 24, 2015
3,561
Yes of course, I was thinking of capture, you can go down to 1.2Khz with 20mhz system clk is that too high? What is the application?
M.
Alec_t
Jul 7, 2015
3,821
:confused: I make that a 200uS period (5kHz) with a 25% duty cycle. Or does the "1 in 50uS" and "0 in 150uS" relate to the pulse rise and fall times, respectively?
There should be no problem doing that using delays. 50uS is 250 instruction times.
aymensmurf
Mar 14, 2016
28
M.
aymensmurf
Mar 14, 2016
28
the problem using the delay is that the cpu lose some time (us) repeating the (loop, for ... do, while(), if () ).
Then you need to use interrupts. Determine when each pulse starts and stops and use the timer to interrupt at those times and toggle the outputs.
aymensmurf
Mar 14, 2016
28
it will get really really complicated to do interrupts for every pulse
Then I guess you should just give up.
Seriously, though:
If the pulses are all on increments of 50uS you can set an interrupt to occur every 50uS and decide what needs to be done at each interrupt. This would be less complicated, but more overhead. How much of the processor time is needed for the other tasks?
