Ak, thanks very much for these circuits. I would like to try and adapt the first one for a very specific project. I want to be able to detect, with high sensitivity, when a solid object (a croquet ball) hits a wooden upright peg. I have tried using a 555 timer chip with a sensitive switch but it works it lacks the sensitivity I need and it takes up too much room because of the relay etc.Schematics for two of the many alternate circuits to do this task. The upper one is a standard monostable followed by a logic-level N-channel power MOSFET, and everything runs on the lamp batteries. R3 can be changed to a pot for variable lamp on-time. The lower one is based on an oscillator/counter chip, with separate power for the timer and the lamp. These circuits assume the piezo makes at least 2 V or 6 V. If not, there are simple mods for lower input signals. Questions?
ak
Would it be possible to adapt your first circuit to do the following -
1) run with a 9 volt battery
2) light a 6 volt LED strip for a controlled length of time.
I have limited electronics experience so would welcome details of any component changes you would suggest.
3) I planned to use the Minisence 100 transducer
http://www.digikey.com/product-search/en?site=us&lang=en&Keywords=MSP6915-ND
Happy to provide more details and also use your second circuit if you think it would be better.
BRD
