Adam Funk
- Jan 1, 1970
- 0
I've been playing with a piezo transducer in 556 circuits (at higher
frequencies than with LEDs). The one I'm using is KPE-163, and the
specification says:
Rated Voltage (Vp-p) Max 30
Current Consumption (mA) Max. 10 @10Vp-p, square wave, 4.8Hz
and it has two leads: one black and one red.
I was wondering whether it would work in a double-555 multivibrator
(powered by a 9V battery) described as having push-pull output, and it
does (I think I had some resistance in series just to be careful). So
I wondered whether the implied polarity in the lead colors was
significant.
AFAICT from trying it turned both ways in a single-555 multivibrator
(between the ground and 9V square wave output), I suspect it isn't
actually polarized. Comments?
Also, does the specification mean that the actual current when you
apply 10Vp-p voltage is 10 mA, so (unlike LEDs, for example) it
doesn't need any protective series resistance at that voltage?
(I have 5 of these and they were cheap, so I don't mind burning a
couple out for educational purposes.)
specification says:
significant.
