PIR hc sr501 sensitivity
gwidijanto
Jun 28, 2023
3
to increase sensitivity in hc sr501,
which direction of 1Mohm trimpot must turn?
toward minimum i.e = O ohm or
toward maximum i.e = 1M ohm?
tq
Delta Prime
Jul 29, 2020
2,996
Depends on the configuration of your trim pot! And how you hooked it up!
I would start in the middle 500K ohms.
But since I've used one the exact same one my findings are.
Full CW, the range of sensing increases, and the maximum sensing distance range is approximately 0-9 meters.
Full CCW, the distance is reduced, and the minimum sensing distance range is approximately 0-5 meters.
CW=turn it clockwise!
CCW=turn it counterclockwise!
You got a clock? Do you have a lens on your detector?
What's the matter cat got your tongue?
[mod edit: removed unlicensend stock image]
gwidijanto
Jun 28, 2023
3
tq for your answer, why I ask it, because if you search this topic, some said CCW increase sensitivity, other said decrease.. confusing.. so to make sure I ask using resistance of the trimpot:
to increase sensitivity,
which direction of 1M ohm trimpot must turn?
tq
gwidijanto
Jun 28, 2023
3
tq Delta Prime,
this is confusing me :)
Delta Prime
Jul 29, 2020
2,996
Okay I'm wrong,I think, I don't know anymore!!
Turn it all the way to the left counterclockwise stand 7 meters away and jump around ...see what happens. As everyone else can tell... it's past my bed time.
Good night!
Delta Prime
Jul 29, 2020
2,996
Or what is confusing you the two potentiometers? Just turn the one on the right with the arrow forget about the other one. And jump around 7 m away
14,317
The resistance of the trimpot is constant (measured between the endpoints). What changes is the divider ratio which varies with the position of the wiper. Typically one would connect the wiper and the endpoints in such a way that the divider ratio is maximum (i.e. approx. 0) with the wiper in the leftmost position and minimum (i.e. approx. 1) with the wiper in the rightmost position. But this is by convention only. One can also swap the endpoint connections and the behavior is reversed.
Also the divider ratio alone doesn't tell you which is more sensitive or less sensitive. This depends on how the potentiometer is used within the circuit.
Another source of confusion: sometimes cheap cloned boards from PRC are constructed not 100 % identical to the original board and may behave differently than the original.
Therefore: RTFM.
