PIR motion sensor audio player
vijaysai1081
Jan 7, 2023
I want to play audio when there is presence of human or animal. I connect
HC-SR501 Pyroelectric Infrared PIR to a simple audio(no microcontroller) chip that plays audio that is used in toys. I connected the output of PIR to the audio play pin. The issue I'm facing is when the PIR senses someone it plays the audio but it goes into a loop. The audio does not stop even when there is no one around. It just needs one trigger and it keeps on playing. Can anyone please tell me where I am going wrong. I changed the jumper settings with single trigger and multiple trigger. I used pull up resistor. None worked. I still face the same problem.​
danadak
Feb 19, 2021
1,104
The sensor has a delay to turn off after it has been triggered :
Regards, Dana.
vijaysai1081
Jan 7, 2023
Regards, Dana.
Thanks Dana for the reply. The delay to turn off is only for how long the audio plays. I changed that. Once the audio clip completes it starts again from the beginning.
I will tell what I tried to find the error. I put the PIR sensor inside a closed box with a small opening in front of the sensor. I waved my hand in front of the hole and closed the hole. The audio started playing. Once the audio completes it should stop as the hole is closed and the sensor cannot sense anyone. But the audio does not stop it plays non stop. I want to know what is making the audio play even when the sensor is idle. If the sensor is not idle what is making to trigger continuously.
Regards vijay
